Loader JD 1070 assistance neede
   / JD 1070 assistance neede #1
BuzzyG
Bronze Member
Hello, boys! I hope all is well with you.
This seems like a really stupid question, but here it is.
I have just acquired a John Deere 1070 that works well in every capacity. But I cannot find two things:
1. The 4WD switch.
2. A place to add hydraulic fluid.
Can you help me with that?
Thanks!
   / JD 1070 assistance neede #2
Engage 4wd by pulling up on a small fwd facing lever on the left side of the seat platform. It should rise up about 1" when fully engaged. Best to do this when the tractor is moving and with the clutch in. Same for disconnect. Shove the lever down ward.
Add hydraulic fluid at the back by removing the yellow plastic cap twist off cap.
Check fuel filters, one at the base of the tank and the one everybody forgets about at the engine on the right side at the injector pump.
Thank you so much.
I should be on the way to usefulness now.
2008 JACK COUNTY  130BBL VACUUM TRAILER (A50854)
2008 JACK COUNTY...
2012 Ford Escape XLS SUV (A50324)
2012 Ford Escape...
Lot of 3 Dell Desktop Computer (A48083)
Lot of 3 Dell...
Apache 8800E Gasoline Generator (A50860)
Apache 8800E...
2025 K1220 UNUSED Single Garage Metal Shed (A50860)
2025 K1220 UNUSED...
Misc Items (A50860)
Misc Items (A50860)
