It's 8:30 at night, you know that you should quit but almost done so...
   / It's 8:30 at night, you know that you should quit but almost done so... #11
The beauty of retirement means that you don't have to extend your work day beyond what your body can handle. Everyday is a work day so tomorrow will work just as well as today.
I used to try to mow my 6.5 acre yard in one day buy now I just mow a section at a time. If it takes me 3 days that is OK.
   / It's 8:30 at night, you know that you should quit but almost done so... #12
Supper is at 5 pm. I know what is best for me, so I plan my day with that in mind. Mrs.tiller is happy when I am on time.
   / It's 8:30 at night, you know that you should quit but almost done so... #13
I am working on a lamp and had to drill a couple of holes in a sheild/partition. I didn't want to drill them in the wrong two corners so I made yet another trip of two hundred feet to the garage for the thirtieth time, just to double check. Made a mark with a sharpie. Drilled holes. Later when I went to assemble it, I realized that I drilled one in the wrong corner, exactly as I had tried to prevent. I have no explanation! Yet another trip required and the job of filling an unused hole!
   / It's 8:30 at night, you know that you should quit but almost done so... #14
I broke my jaw years ago by working late. Now the rule is that I quit by 9 at night. Otherwise I'm apt to make foolish mistakes.
I finally got my snowsled almost together again... now I'm back where I was at 20 minutes before I started this thread.
It's actually turned out for the better, as I apparently needed to replace the recoil spring. At least it initially broke when the sled was on my pickup tailgate, instead of 10 minutes earlier when I was 5 miles in the woods.
1998 CHEVEROLET 1500 LONG BED PICKUP TRUCK (A58018)
1998 CHEVEROLET...
2023 NEW HOLLAND WAGON TONGUE AND LOADING CHUTE FOR NEW HOLLAND SQUARE BALERS (A55315)
2023 NEW HOLLAND...
2004 Cat 730 Articulating Off-road Dump Truck (A59213)
2004 Cat 730...
2025 SDLANCH TRAILED CRUSHER (A58214)
2025 SDLANCH...
New/Unused CFG Industrial MX12RX Mini Excavator (A57453)
New/Unused CFG...
New/Unused SD Lanch SDLE20 Mini Excavator (A57453)
New/Unused SD...
