ISO wisdom and guidance
   / ISO wisdom and guidance #1
clueless1
my husband and i are trying to decide on a quick-attach and are in need of some advice. so far we are thinking we will go with the tach-all but are still open to ideas. i honestly know very little about how it even works but i am trying to learn. i see that the tach-all has 2 3/4" over stock and i believe that means more power (sounds like tim taylor). i guess i am under the impression that is the deciding factor. please help.
thanks,
-clueless1
   / ISO wisdom and guidance #2
Could you explain this a bit more?
What do you plan to do with this attachment?
   / ISO wisdom and guidance #3
Are you putting a quick - attach on a loader setup, or on a 3-point? Either could apply from your description.
I'm just guessing, but are they saying that the quick-tach will extend the (loader; 3 point) an extra 2.75"? In general, that slightly lessons the weight you can put on the (loader; 3 point) by just a little bit, plus you lose the weight of the quick-tach itself.
A little more info? Even mentioning your tractor, & the implements you are wishing to use with it, would help.
--->Paul
KENMORE WASHER & DRYER COMBO (A57192)
KENMORE WASHER &...
2005 International 4300 Telsta Telescopic Bucket Truck (A55973)
2005 International...
2013 Ford F350 (A55973)
2013 Ford F350...
2016 CATERPILLAR D6K2 LGP CRAWLER DOZER (A52707)
2016 CATERPILLAR...
5' ROTARY MOWER (A52706)
5' ROTARY MOWER...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A55852)
2019 Ford F-150...
