Iseki TS2205
   / Iseki TS2205 #1
Ed Wells
Does anyone know if you should put transmission/hydraulic fluid or 80/90 wt gear oil in the transmission reservoir for this tractor?
   / Iseki TS2205 #2
Ed I would say Hydraulic fluid if its close to the Models I,ve have , & 1 was a 2202 that I traded off . the only thing i,m aware of that takes gear oil is the Front Differential on the 4 wheel drives . Hopefully someone that has that Particular model will say for sure . Bob
   / Iseki TS2205 #3
Ed, on your older TS tractor, like my TS1610F, the tranny and hydraulic reservoirs are separate and don't take the same fluid like Bob's newer model does.
On the transmission oil, you don't use hydraulic fluid, use the tractor transmission oil they sell at Wal-Mart (or?) in the 5 or 10 gallon containers that conforms to the JD 303(?) spec, it''ll say on the back panel. The hydraulic reservoir, separate from the tranny case, uses a standard hydraulic fluid (for mobile equip.?). Hope this helps.
Bill
   / Iseki TS2205 #4
Woop,s !! :eek: , Sorry I Wasn,t aware the Older models were any Different, Thanks for Correcting Me Bill & Clearing it up. Bob :D
2019 Ford F-550 Bucket Truck (A51039)
2019 Ford F-550...
2021 ALLMAND BROS, INC. NIGHT LITE LIGHT TOWER (A50854)
2021 ALLMAND BROS...
2017 John Deere 30G Mini Excavator (A50322)
2017 John Deere...
2022 New Holland Workmaster 120 MFWD Compact Utility Tractor (A51039)
2022 New Holland...
1240 (A50490)
1240 (A50490)
https://www.accessnewswire.com/newsroom/en/healthcare-and-pharmaceutical/slimjaro-vs-burnjaro-reviews-a-comprehensive-analysis-of-benefits-and-1044755
https://www.accessn...
