Is this normal for the pto on a branson 3510
   / Is this normal for the pto on a branson 3510 #1
dwightennis75
I used it today and when I slowed down the pto sounded like it is ratchiting so I went on and slowed down again it did the same thing I had the brush hog hooked up by the way this is the first time I have used the pto since I bought it about 2 weeks ago is there such a thing as a ratcheting pto
   / Is this normal for the pto on a branson 3510 #2
Sounds normal.
Your tractor has an internal overrunning PTO. It is there so a brush mower Etc. can't push the tractor ahead through the driveline while the mower speed is winding down.
Thanks for the reply
   / Is this normal for the pto on a branson 3510 #4
I to noticed this same thing with my Century 2035.
When I would let the bush hog slow from full speed it would click/ratchet as it slowed and I was worried something could be wrong.....
So this must be normal for my tractor also.
Should I assume this to be correct.
I didnt want to start a new thread since this is the info I was curious about to.
Everything seemed normal ...but the ratchet sound on decel of bush hog from the pto.
5th Wheel Dolly (A49461)
5th Wheel Dolly...
1264 (A50490)
1264 (A50490)
2004 Ford F-250 4x4 Crew Cab Mechanic Service Truck (A49461)
2004 Ford F-250...
2007 PETERBILT 335 SERVICE/LUBE TRUCK (INOPERABLE (A50854)
2007 PETERBILT 335...
2021 Cat D5 LGP Dozer (RIDE AND DRIVE) (A50774)
2021 Cat D5 LGP...
2010 TROXELL 140BBL TRI AXLE VACUUM TRAILER (A50854)
2010 TROXELL...
