Is there any harm parking on a slope
   / Is there any harm parking on a slope #1
mthornton
wetumpka,AL
2013 Mahindra 3016
I am preparing to purchase my first tractor(larger than riding mower) soon and am plannig to park it behind my "man house". I can cover it with a tarp initially but plan to extend the roof line to shelter from the weather. Since my property is sloped from back to front, the tractor would be parked on a slight side slope behind the man house. Is it ok to park the tractor on this slope for extended periods of time(storage)? Is there any damage that could occur since the fluids would not be on a level surface? I hope this isn't too dumb of a question, but I didn't know and I figured you guys would. Thanks.
Mark
   / Is there any harm parking on a slope #2
Leaving it set on a slope is no more damaging to anything than leaving it set on flat ground. Run it often enough to keep the battery charged and lubes circulated and it will be fine... I would chock the wheels rather than using the brake for extended periods of time. Naturally do everything needed to prevent a rollaway in the worst possible conditions.
Thanks.
   / Is there any harm parking on a slope #4
No "dumb" questions, except for the one we fail to ask. :thumbsup:
   / Is there any harm parking on a slope #5
We used to park the Ford 8N, JD-A, and Case 730 on the hillside of our driveway whenever the battery (or gen) was bad. Put them in top gear, release the brake, and pop the clutch to start them. Only failed to work once or twice that I recall.
   / Is there any harm parking on a slope #6
He referred to sideslope. No issue except maybe if you have an old tractor with an axle seal that seeps a bit.
larry
2021 DORSEY 53FT FLATBED TRAILER (A58018)
2021 DORSEY 53FT...
2005 CHANDLER 500 BBL FRAC TANK (A58214)
2005 CHANDLER 500...
2015 Ford F-150 Crew Cab Pickup Truck (A56858)
2015 Ford F-150...
1993 20ft. Custom Deck Over Equipment Trailer (A56857)
1993 20ft. Custom...
2018 MQ POWER WHISPERWATT DCA-25 GENERATOR (A58214)
2018 MQ POWER...
LOT: (2) Kimball Midwest 4-Drawer Hardware Cabinets, (1) 2-Drawer Hardware Cabinet w/Contents & (A59076)
LOT: (2) Kimball...
