jonyyuma
Elite Member
- Joined
- Sep 14, 2010
- Messages
- 2,922
- Location
- 35 miles North of Memphis,TN
- Tractor
- kubota L3000dt, ford 8n1952
The county schoolbuses in our little state have been burning Cng for some time???l
Diesel engines that are in potential explosive environment locations are suppose to have a positive air shutoff system and redundant system! We routinely check these every 250hrs of operaion.I believe thats how the Deepwater Horizon explosion occured. The diesels on the deck of the platform ran away on the gasses coming out of the well.
Actaully, diesel engines DO NOT require a spark ignition system to run on NG... the compression is high enough int he cylinders that it will compression ignite very easily. We have installed many dual-fuel conversion systems on large modern diesel engines. These engines are used in the drilling and fracing industry. They take advantage of wellhead gas from nearby well-sites to vastly lower the diesel fuel consumption. The technology is already here, its EPA certified and the products are already in use... It might take some time to get the average auto consumer to buy in... but its already here. Personally, I believe the "big 3" need to get off their backsides and start building factory CNG vehicles.... Its cheap, clean, and abundant but most importantly, it here in American soil!.
Why not burn somebody else's oil and keep our own for when everybody else runs out?
The NG does not ignite from compression, the engine would suffer detonation as if it was supplied LP above the lower explosive limit.
NG works in diesels with pilot ignition. The injection pump is operating and injects a slow idle metering levels. Power is increased by adding NG to the intake air stream.
NG or any gas type fuel does not require an ignition system to ignite in a diesel. the cylinder temp is high enough to ignite. if the NG is injected in the place of diesel, you cannot have detonation if there is no fuel present. once it is injected, then ignition occurs, JUST LIKE IT WAS RUNNING ON DIESEL. the only difference is timing of injection. Cummins actually sells CNG engines that are basically DIESEL engines with modified timing for cng. diesels can even run on alcohol! most (if not all) of top pulling tractors run alcohol in a DIESEL engine!
