Installed New Gator Blades.
   / Installed New Gator Blades.
I'm not really sure. I needed new blades and everyone seems to like these (and they are pretty cheap), so that's what I went with.
I'm not sure I'll really get to use them this year to test. Looks like the last mowing of the season was already done. Grass isn't really growing any more.
-Larry
anthonyk said:
What's the gator blade do that's different.
I've never seen one before.
anthony
   / Installed New Gator Blades. #12
Anthony: Actually on E bay if you search for "Gator Blades" there are some good pictures.
I have a spare set and can take some pictures if needed.
-Larry
   / Installed New Gator Blades. #14
yep, that deck is one Pain in the butt to remove and re-attach, I did it last year to attach the snow blower. Not sure if it is worth it this removing this year, may have to just deal with the snow. My fill tube for the trans fluid is the same, takes forever to fill.
I ended up using a rubber strap wrench to get the hydro filter off.
I got it off with one type of wrench, and snugged it up (carefully) with a strap-type.
It's tight under there :)
-Larry
   / Installed New Gator Blades. #16
anthony
They're mulching blades. The back of the blade is formed with three small "wings" that recut the grass clippings, making the clippings finer and therefore quicker to decompose.
Picture what a Mower Blade designed by Stephen King would look like, and you'll probably be pretty close :)
-Larry
anthony
   / Installed New Gator Blades. #18
Ah, so it's a mulching blade. Thanks.
I was told by cub cadet that my 1046 came with mulching blades.
I never use the plug because it leaves an annoying line of grass.
maybe the gator blades would get rid of that.
anthony
CASE CX330 EXCAVATOR (A52707)
CASE CX330...
2019 CATERPILLAR 259D SKID STEER (A52705)
2019 CATERPILLAR...
2011 Liebherr L586 Wheel Loader (A55218)
2011 Liebherr L586...
2008 Ford Focus SEL Sedan (A54815)
2008 Ford Focus...
CHAMPION C80C MOTOR GRADER (A52707)
CHAMPION C80C...
