Tractor Sizing Info for 86 horese JD 3120 Tractor
   / Info for 86 horese JD 3120 Tractor #1
ddoby
Kaufman, TX
John Deere 3120 & New Holland WM45
Does anyone have any info for the 69-71 86 horse JD 3120 tractors? I can't find much. Everything I find under 3120 is for the newer compact tractors.
   / Info for 86 horese JD 3120 Tractor #2
Check and see how similar this is to a 3130. IIRC the 3130 is 86hp too and should be very similar. Is yours a 6 cylinder?
What kind of information are you looking for?
   / Info for 86 horese JD 3120 Tractor #3
Most likely a Canadian or European version of the 3020. Put Model 3120 in the model search of JDparts and see what comes up.
   / Info for 86 horese JD 3120 Tractor #4
It is different from the 3020, more the size of a 4020 but not as good imo.
This 3120 he is inquiring about is a 6 cyl tractor with a 303 cu in engine which is about half way between the 3020 and 4020 engines.
I agree it is an European version with parts that are more difficult to locate in most cases.
2007 TROXELL KILL/TRANSPORT TRAILER (A50854)
2007 TROXELL...
2007 NLB Trailer w/Mounted Shell Side System (A50860)
2007 NLB Trailer...
2014 VOLVO VN SERIES DAY CAB (A50854)
2014 VOLVO VN...
2025 K4525 UNUSED Double Garage Steel Barn (A50860)
2025 K4525 UNUSED...
2012 FREIGHTLINER CASCADIA (A50854)
2012 FREIGHTLINER...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51222)
2018 FREIGHTLINER...
