In-line fuses for Mahindra 2015
   / In-line fuses for Mahindra 2015 #1
Mahindragb
Lawrenceville, GA
Mahindra 2015
Are there in-line fuses on the Mahindra 2015 other than the 50 and 60 amp ones? I heard a pop when I tried to start the engine. Now there is no electrical activity, not even the panel. All the fuses in the fuse box and the 50 and 60 amp fuses check out with a meter.
   / In-line fuses for Mahindra 2015 #2
I would first check your battery connections both at the battery and the respected termination for the positive and ground.Since the fuses check out good, sounds like you may have heard one arc under load of starting.
Regard's
Sean
2023 John Deere 6110M Utility Tractor (A50657)
2023 John Deere...
2015 Mitsubishi Mirage DE Hatchback (A48082)
2015 Mitsubishi...
KUBOTA M7040 TRACTOR (A51406)
KUBOTA M7040...
Gas Air Compressor (A50860)
Gas Air Compressor...
John Deere HX15 Flex Wing Rotary Cutter (A50860)
John Deere HX15...
2016 Chevrolet Impala Limited Sedan (A48082)
2016 Chevrolet...
