I'm Baaaaaack!
   / I'm Baaaaaack! #1
SnowRidge
Elite Member
East Tennessee
Power Trac PT-425 / Branson 3520
Title says it all.
Had some 'interesting' experiences. Have new property, acquired a boom mower, and had to repair my cracked brush cutter, among other things.
I will post some details later.
   / I'm Baaaaaack! #2
Welcome back. Interested in seeing your fix for the cracked brush cutter because it seems that I have one of those also.
   / I'm Baaaaaack! #3
I just sold a Rhino extra light weight 6' mower that the base plate for the gear box had cracked into 3 pieces. The previous owner ran it so long the bottom of the gearbox had worn 1/4" off one side from sitting uneven and loose. Cutting that off, and replacing it wasn't that bad, after getting the stump jumper loose. I took a piece of 8" wide plate that is 1/2" thick and welded two short plates to the sides forming a piece of channel. Cut the center hole with a torch, carefully, and then drilled the bolt holes. Welded that to the braces and supports, and the light weight decking and sent it down the road. Hopefully it won't be back!!
What kind of boom mower did you get? Pictures are always nice!
David from jax
   / I'm Baaaaaack! #4
SnowRidge said:
Title says it all.
Welcome back -- I'm anxious to hear the details!
   / I'm Baaaaaack!
The boom mower is the Power Trac offering. I will post a report as soon as I get a chance.
   / I'm Baaaaaack! #6
I know there are going to be some people on the PT thread waiting to see some pictures of that.
David from jax
3000 Gallon Black Poly Water Tank (A49461)
3000 Gallon Black...
Payment Terms (MUST READ) (A50775)
Payment Terms...
Gravely Compact Pro Zero Turn Mower (A50860)
Gravely Compact...
2019 BOBCAT T770 SKID STEER (A51242)
2019 BOBCAT T770...
Huffy NEL LUSSO Bicycle (A50860)
Huffy NEL LUSSO...
Headache Rack (A50860)
