IH 674 Gas engine, Air filter
   / IH 674 Gas engine, Air filter #1
enen
grassie, ontario
ih674, JD1025R
HI
I have tried ordering a new air filter. The replacements are approx 11" long
The proper size is approx 10" long
has anyone else run into the problem?
Any source of correct size filter?
Thank you
Ian
Grimsby Ontario canada
   / IH 674 Gas engine, Air filter #2
This is the one I found through NAPA, that they show for the IH 674 gas with the 3.3L or 200 cu. in. C-200 gas engine. Shows to be 10.28" long.
NAPA AUTO PARTS
Great, thank you
I don't know why the parts placing have the wrong filter listed for this tractor
   / IH 674 Gas engine, Air filter #4
I was thinking because they were giving you the one for the Diesel, and it possibly being a bit bigger. The Case/IH online parts catalog only shows the diesel 674. I searched NAPA for it, using the part number shown for the diesel air filter, and shows the same filter number that I posted in the link above. Apparently a glitch in the system somewhere..!!
I even called the local dealer with the part number directly off of the correct filter and was told it was discontinued
I'll let you know if the napa filter is the right size
   / IH 674 Gas engine, Air filter #6
Type the number in the space top left, then be sure to click on the small "interchange" box. NAPA AUTO PARTS - Home
I found the Baldwin PA2383 fits
The original filter has a band of holes approw 4" high in the exterior for air flow
The baldwin exterior is completely covered with holes.
I don't think that is a bad thing???
2013 PETERBILT 389 (INOPERABLE) (A58214)
2013 PETERBILT 389...
2025 Wolverine MAD-12-12D Auger Mini Skid Steer Attachment (A56857)
2025 Wolverine...
LOT: Fuel Transfer Tank, Tool Box, 12 Volt Fill-Rite Pump (A59076)
LOT: Fuel Transfer...
CATERPILLAR 279C SKID STEER (A52709)
CATERPILLAR 279C...
2016 FORD F350 FLATBED TRUCK (A58018)
2016 FORD F350...
T-POST PULLER (A52708)
