ignition switch issues
   / ignition switch issues #21
thanks guys.
The wd-40 worked . (it is all I had on Hand) just sprayed it in the key slot for now. may have to take apart as suggested (but at least I can get it started right now.) Maybe it was the cold weather causing the grease to cake/harden as several guys suggested.
me happy now
"worked for now"------ but I bet it continues for a very long time. Don't be in a rush to open it as the little tabs will snap off.
My treated switch is still A-OK after 4 years or so with my spare sitting on the shelf.
I have split old switches and they were all caked and dry generally with the tension spring hung up by the caked grease.
While I expected to find warn contacts that was not the case. For that reason I habitually spray a small squirt of WD.
Also do all door locks from time to time and have not had a frozen car door lock for the last 20 years.
   / ignition switch issues #22
I have had trouble with the switches on my tractor also. 2 light/turn signal switches and just got my fourth ignition switch.. Cost me $100.00 for switch and a nice weather weekend. It is enough to make me sorry that I bought this tractor (venting, friend had to go get his Kubota so we could move logs. He took get joy in turning it on and off.) I coated the last switch with liquid electrical tape and I always cover switch. My storage conditions are similar to bvanek's. Probably get parts from same dealer. I like the tractor (now that 4 wheel drive issue resolved) but could not recommend it. Pretty silly for Kioti not to deal with the issue.
Just spray some Fluid Film in the switch. Fixed mine 2 years ago. No trouble since. it wouldn't hurt to spray it once a year, but I haven't remembered to do it.
   / ignition switch issues #23
I have never heard of Fluid Film.. I will give it a try. Just looked it up on Amazon Thanks
   / ignition switch issues #24
Good stuff, I use if for everything on the tractor that needs lubing that does not have a grease Zerk.
The Dr. Mower company started pushing it in their catalog years ago for their machines. I never thought much about it and never tried any, until someone on here convinced me to try some. They sent me a small free are-sol can of the stuff, I used it and ordered several of the full size cans. I was hooked.:fishing:
John Deere XUV 835M (A56469)
John Deere XUV...
2008 Featherlite Portable Office Command Center T/A Trailer with Wacker Neuson G50 Towable Genera... (A56858)
2008 Featherlite...
2017 Ford Taurus Sedan (A55853)
2017 Ford Taurus...
2014 Volkswagen Passat TDI SE Sedan (A55853)
2014 Volkswagen...
2013 International WorkStar 7400 Altec AM547 50ft. Bucket Truck (A55852)
2013 International...
Kivel Quick Attach Forks (A56469)
Kivel Quick Attach...
