sd455dan
Super Member
- Joined
- Oct 23, 2012
- Messages
- 6,282
- Location
- North Idaho
- Tractor
- Rhino 554, Ford 550 TLB (JD X500, MTD, Gilson riding mowers) Ford 3000-Sold
Outstanding Fred :thumbsup:
Hope the success continues for many years.
Wouldn't too lean be too hot? Or is that gassers only?After the engine fix I left the fuel the way it was before the turbo install. The power with the turbo alone is far better than without, it's a whole different machine again.
I think I had the fuel setting well above what is recommended. I wonder what is better more boost and less fuel or more fuel and less boost; I want both.
Gasses need to keep the magic stoichiometric 14.7 to 1 air to fuel ratio. If not you are running lean or rich. You have to starve the engine for air & match with decreased amount of fuel to decrease power. On a diesel the amount of fuel injected is all that controls power. Less fuel, less power, less heat. It always sucks in the "same" amount of air (or has it crammed in by the turbo).Wouldn't too lean be too hot? Or is that gassers only?
Yeah, I suppose I knew that.Gasses need to keep the magic stoichiometric 14.7 to 1 air to fuel ratio. If not you are running lean or rich. You have to starve the engine for air & match with decreased amount of fuel to decrease power. On a diesel the amount of fuel injected is all that controls power. Less fuel, less power, less heat. It always sucks in the "same" amount of air (or has it crammed in by the turbo).
