I have a John Deere JD400 Diesel
   / I have a John Deere JD400 Diesel #1
hotrodinjt
Joshua Tree, Ca
JD 400
Hi All,
I am Scott. I live in the high desert of southern California where it freezes at night this time of year. I am here to learn and get some help. I have spent many hours online looking for information on my tractor and can't find the answers I need. I hope you can help. I have a John Deere JD400 Diesel tractor. I am hoping you can help me with a few things. The tractor story is: I had the tractor a few years and it worked great until I was running it on a warm day and out of the exhaust pipe came white smoke. I checked the oil and guess what, no oil!!! So I turned it off and let it cool off and added oil. After it cooled down it would not turn over. So about 30 days went by, I took the air intake off, added a quart of Marvels mystery oil, let it soak in for a week or so then turned it over, and it's turning s-s-slow. An engine builder told me I need to rebuild it. So, I need an overhaul how-to book. I need to move it in the shop and tear it apart. I have never done a tractor and don't have a fork lift to move it or pull the engine. Any ideas may help me. So I need to find the year and where to get a book. Here is what's on the Tractor:
John Deere 4 cylinder Diesel Tractor "JD400 "
Engine tag: type: M53TW Serial: 162130T
Under drivers seat tag: type T5W3D serial: 1063481
Bucket arm tag: type: e-7400 serial: 0080230
I have been walking around kicking my own stupid butt for not checking the oil!!! So you don't need to tell me about it. I now check the oil and water in my other autos more often!!!! Lesson learned the hard way!!! I don't know how to post a pic on this post.
Any useful information would be great. Scott
   / I have a John Deere JD400 Diesel #2
:welcome:
   / I have a John Deere JD400 Diesel #3
You can order a repair manual from JD by calling 866-213-3373 or 414-466-6060
   / I have a John Deere JD400 Diesel #4
   / I have a John Deere JD400 Diesel #5
Found this:
The JD400--Industrial version of the 2020
If that info is correct, you might just be able to get a shop manual for a 2020. It should be a lot easier to come by.
There are several differences between a 2020 & a 400's hyd systems. The hyd's are somewhat alike but different. I'd spend the extra $$$$$ for the correct service manual.
   / I have a John Deere JD400 Diesel #6
Thanks Jim, I was just going by what that website was saying. I didn't know.
Thanks guys. I called JD and got the digital copies of the books, wow lots of work. I was hoping that I could get it going without a rebuild. It does turn over slow and does not make any noise. but its very slow even with two new batteries. I was thinking I could start it and see how it sounds? But I think the cylinders may still have oil in them and making it hard to turn over?!? How long should it take for the oil to drain out? Or am I wrong about thinking I could start it!?? What can I do to get the pressure off the cylinders to make it easy turn over? Thanks for the help so far! S
   / I have a John Deere JD400 Diesel #8
I think the engine components that are causing it to turn over slowly are not the pistons & liners but the rod & main brgs. One could remove the pan and inspect the rod/main brgs for damage. There are also 2 balancer shafts in the lower part of the engine block(photo attached) that could have brg problems. Only easy way to release compression would be to remove injectors.
Hi Tx Jim, I talked to someone about just that. I Am thinking about doing this when I have time. I was also told I can't take the engine crank out without taking the engine out. I Loosened the injectors but did not pull on them thinking the pressure would push them out? I did not want to break the o ring! I think I can spray some WD on them and let it soak in so the o rigs will not break. They have been on the tractor for years. I don't know much about diesel tractors so I am asking the stupid questions so I don't do something that would cost me more money. I have more time than money! thank you for your help and ideas. Scott
   / I have a John Deere JD400 Diesel #10
Crankshaft or balancer shafts can't be removed while engine is in tractor.
2015 Toyota Camry Hybrid Sedan (A48082)
2015 Toyota Camry...
UNUSED Steel Diamond Plate (A50860)
UNUSED Steel...
Tubing A500 Grade C 6in. SQ X 1/4in. X 28ft. (A50860)
Tubing A500 Grade...
2016 Ver-Mac S/A Towable Trailer Message Board (A49461)
2016 Ver-Mac S/A...
2014 Brent 1596T Dual Auger Grain Cart (A50657)
2014 Brent 1596T...
Craftsman LT2000 42in. Riding Mower (A49346)
Craftsman LT2000...
