I bought the ubiquitous Carry-All
   / I bought the ubiquitous Carry-All #1
TomOfTarsus
North of Pittsburgh near Airport
1999 New Holland TC18 HST
Hello, all!
I didn't know whether to post this in "Attachments" or here, or maybe even Customization.
I went to my local TSC yesterday and bought the Carry-All frame for the back of my little NH TC-18. One of my biggest reasons for buying it was to haul firewood from places I can't take a trailer into. So obviously I will be bolting (or pinning) something to this little beauty.
But there is a wider view, so I thought, why not open up a thread where people can show off what they've done with a 3PH carry-all frame.
Give me some ideas. Esp. when it comes to carrying firewood!
Tom
   / I bought the ubiquitous Carry-All #2
How about making several rakes out of pallets and using the carry all as forks. Load the wood once and pick up a different rack.
MarkV
Thanks, Mark!
Funny, I was thinking of using the thing as a "fork lift" to lift an old concrete utility tub, but didn't even think about stacking on pallets and then just picking it up!
But let's keep them ideas coming!
Tom
   / I bought the ubiquitous Carry-All #4
Actually, I bought a TSC Carry All specifically to use as forks to carry my firewood on pallets. It was cheaper than buying steel and welding up a set of 3 pt pallet forks that I designed. So far, though, I have only two pallets-gotta work at that.
I had thought of building a chainsaw and accessories bench for it, that would be used to carry the saw, oil, fuel, etc between the shop and where I'm cutting, and then just set it down while moving the wood on pallets. So far, though, i mostly put all that stuff in the back of the gator, and collect the wood at a later time.
   / I bought the ubiquitous Carry-All #5
I basically built a "deck" on mine. 2X4 treated sleepers on the horizontal and verticals with 5/4 deck boards screwed to the sleepers. Drilled and carriage bolted through the wood to the carryall frame. It's not necessarily pretty, but handy. Carries firewood in the winter, 55 gallon watering can in the summer, tree planting in the spring and just about anything else in between. It's a great, height-adjustable work table. I haven't yet had the need to add sides or a back but I do have the FEL at my disposal as well.
Yeah, as I thought this through, part of my problem is that I'm on some mighty hilly ground, so a pallet of firewood w/o some additional security is just going to roll off before I get very far. I'd have to use ratcheting straps around it or something.
Plus it appears the carry-all angles are deeper than my pallets and won't just slide in. And I don't have a "hot wrench."
So I'm still letting this one stew in the ol' noggin. I like the watering drum idea!
   / I bought the ubiquitous Carry-All #7
I thought about buying one of these to use as a light-duty fork lift, but you don't get a tilt feature unless you add a hydraulic top link.
By the time I add remotes and the hydraulic top link, I will have spent darn near enough to just by pin-on forks (that replace the bucket) for my FEL -- which is what I'm going to do. The three point on my little B7100 is only rated for 400 lbs, where as the DuAl 145 FEL on it can list 680 lbs, and lift it a bit higher.
If I had a larger tractor with more three point capability, I would probably do the hydraulic top link and 3-point forks, as this puts the load on the much-larger rear tires which would be easier on the lawn when moving pallets of firewood, which is the main reason that I'm doing the forks.
Yeah, cranking the top link by hand for tilt is no option. My reason for wanting it on the back is capacity and weight distribution. When I have a load in the bucket, it pulls weight off the rears and I can't get up hills. So with the filled tires and the wood in the back, I figure (1) more wood per trip and (2) being able to make the trip in the first place!
Maybe, if I just made up a simple "L" shapedown the back and across the bottom legs, I could load that up and stretch some kind of a cargo net over it?
   / I bought the ubiquitous Carry-All #10
I bought a TSC frame a year ago and thought about doing the pallet thing -then I built a deck of 2x8 PT that is 4'x5'. I found that tying things down to move them on my really hilly property was a PITA so after using that for a while I built a three sided box on top and a tailgate using rack couplers and stake pockets. Then I decided to add tool holders from 2" abs pipe around the edges and a chainsaw holder made from dadoed vinyl decking. After wrestling with it a few times in the outbuilding I added casters to the bottom. Now I find that it stays on the tractor most of the three non winter seasons:eek:.
In the winter it stores a whole bunch of garden and logging tools in the out building. Between the carryall and the front end loader I can carry a fair amount of wood out of some pretty tight spots. If I am really tired I just undo the top link and raise the three point to dump the wood by the wood shed.
I will try to remember to take some pictures of it and post them here on the weekend. If you do a search on carryalls on here you will find all kinds of interesting approaches -- a lot of the ideas above have been done before:eek:
Regards
Steve
Sink with table (A50860)
Sink with table...
2021 John Deere 5045E  Only 86 Hours, Loader Ready, 2WD, Canopy (A51039)
2021 John Deere...
2012 Geringhoff NS1200 Corn Head (A50657)
2012 Geringhoff...
2021 CATERPILLAR D3 LGP CRAWLER DOZER (A51242)
2021 CATERPILLAR...
2023 PETERBILT 579 TANDEM AXLE SLEEPER (A51222)
2023 PETERBILT 579...
2016 Dodge Charger Sedan (A48082)
2016 Dodge Charger...
