I am in the running for a Darwin award...
   / I am in the running for a Darwin award... #1
screamin400
Platinum Member
Lee Center NY
2016 Mahindra 2538, 2016 Mahindra 2655, 2017 CaseIH 75C, 2021 CaseIH 110c., 2020 Kubota svl 65-2, 2022 Kubota svl 75-2, Kubota svl75-3, Kubota M6
Got with a friend of mine who does decals etc. He and I designed a couple of signs for my truck. I wanted magnetic as in the winter I do snowmobile and in the summer I do landscaping. I wanted to be able to change them out. He made them up and they are beautiful. Outstanding job. I could not have been happier until we went to try them on my new truck. Yes, it is aluminum. I forgot.
   / I am in the running for a Darwin award... #2
Hahaha, I can identify with you. I once forgot to remove the two piece PTO shaft from the tractor when I disconnected the bush hog. I never heard it dragging behind the tractor as I put it under the shed. Next time I used it, as I backed out of the shed, the rear of the Mahindra 5035 began rise up as the shaft buried in the ground. That one got my adrenaline going. No damage to the tractor, but the shaft and my pride took a hit. Since your truck has an aluminum body, you might take your design to a wrap business and get them to print you a small vinyl sign. I wouldn't think it would cost much since you already have the art.
   / I am in the running for a Darwin award... #4
I,m surprised there isn,t some steel re-inforcement inside the doors.
Have you gently run a magnet over the door skin to confirm that it is only aluminum under the skin ?
   / I am in the running for a Darwin award... #5
Oh my - Maybe time for some of that thin 3m double sided trim/construction tape and some thin sheet metal strips ?????????????
gg
   / I am in the running for a Darwin award... #6
thats a great idea,,, or you might try pop rivets
I took them and mounted them on my open trailer. I mounted a piece of plywood and then a thin metal plate along with a couple screws so they do not fly off. My guy will make me lettering for the truck just about as soon as my embarrassment wears off
   / I am in the running for a Darwin award... #10
3M Trim Adhesive works - it's what they use for applying door guards and emblems/logos. Sticky, but non-damaging and can be removed by softening with a hair dryer.
Perhaps make the first sign out of a magnetic panel and trim adhesive that and then in the alternate season, the magnetic sign can stick to the stuck on one.
Trailer Hitch w/ 2 5/16 Ball (A56469)
Trailer Hitch w/ 2...
2015 Chevrolet Tahoe SUV (A55853)
2015 Chevrolet...
UNUSED FUTURE MINI EXCAVATOR GRAPPLE (A57193)
UNUSED FUTURE MINI...
2015 Ford Taurus AWD Sedan (A54815)
2015 Ford Taurus...
JOHN DEERE (2) ROW PLANTER (A57192)
JOHN DEERE (2) ROW...
2013 Kenworth T440 Vactor 2100 Plus Combination Sewer Jetter Vacuum Truck (A55852)
2013 Kenworth T440...
