Hydrostat on hills
   / Hydrostat on hills #1
cbg8670
East tenn
Mahindra 26xlt, LS k5055
I am considering either a ck4010se or tym 474 how do the hydro transmissions do on steep hills. My past experience was that a hydro would still roll after letting off forward pedal.
   / Hydrostat on hills #2
That's the reason for brakes and an emergency brake to keep it from rolling. Only with HST there's no need to take it out of gear or put it in neutral or shut it off when you stop.
   / Hydrostat on hills #3
My Branson with HST does not move with the pedals in neutral and engine off unless it's very steep, and even then it's slow. I always use the parking brake though.
With the engine running the transmission provides a lot of resistance with the pedals in neutral. On my steepest road (which is quite steep) I can drop the throttle to idle and take my foot off the pedal and the tractor will go very slow down the hill. I don't need to use the brakes often.
   / Hydrostat on hills #4
I have an HST and out of ignorance, I didn't use the brake until I saw it creep because I didn't drop the bucket.
I have since learned to put it in neutral and set the brake because it is the safe thing to do. Like others said, it doesn't move much but I don't want it rolling over on my foot either.
   / Hydrostat on hills #5
Only problem with HST'S (at least mine- MF GC 1715) if you do not set the brake, and take it out of gear it will [free] roll..... Always brake on, then take out of gear, put in gear then take brake off..... And dropping FEL for the drag it causes on ground is extra security....
   / Hydrostat on hills #6
A HST will creep a little bit but nothing close to freewheeling. They also have brakes.
   / Hydrostat on hills #7
Yup they will do slow roll :oops: as others said "brakes" or lower attachment.
   / Hydrostat on hills #8
Use the brakes the same as you would a gear tractor
   / Hydrostat on hills #10
Echo what the others have said. LOTS better than try to stop and change gears on a geared tractor, especially if going to/fro a lot. Unless you do A LOT of ground engagement work (e.g. plowing, discing, etc.) HST is the way to go.
(1) Push Blade and (1) Disk (A50860)
(1) Push Blade and...
2019 Konica Minolta BizHub C458 Printer (A48083)
2019 Konica...
2017 Mahindra 85P 4WD Tractor (A50860)
2017 Mahindra 85P...
2011 Ford F-150 Pickup Truck (A50860)
2011 Ford F-150...
NEW 2024 LOAD TRAIL 83IN X 14FT Tandem Axle Dump Low-pro Trailer (A51039)
NEW 2024 LOAD...
2014 KALMAR 4X2 YARD DOG (A50854)
2014 KALMAR 4X2...
