Backhoe Hydraulics
   / Hydraulics #1
lew603
new holland tc40
Hi, I have a tc40da with the 757c back hoe. After i unhook the back hoe from the tractor ,do i need to reconnect the two hydraulics connections back together that are on the tractor. Or do they just hang loose and not connected ? I cant find this in the manual. thanks , lew :thumbsup:
   / Hydraulics #2
Yes. Got to compete the circuit.
Kim
   / Hydraulics #3
Kim
100% correct. Just to expand the answer a little, those lines called the "Power Beyond" lines, carry the full flow of the hydraulic pump whenever the tractor is running. Not connecting these lines back together can cause sever damage to your machine and/or overheat the hydraulic fluid.
2005 OVERLAND TANK KILL TRAILER (A50854)
2005 OVERLAND TANK...
1272 (A50490)
1272 (A50490)
2020 J&M 1151-22T Classic Grain Storm Grain Cart (A50657)
2020 J&M 1151-22T...
AC CHARGING MACHINE (A50854)
AC CHARGING...
2012 MACK GU713 DUMP TRUCK (A50459)
2012 MACK GU713...
2022 CATERPILLAR CS54B SMOOTH DRUM ROLLER (A51242)
2022 CATERPILLAR...
