I have no rear remotes on my New holland TC30 for the 3 point backhoe I purchased and wanted to run then as inexpensive as possible... the rear remote kit for the NH is 900.00 and there has to be a cheaper way... i have the 2 spool loader controller and power beyond port... can i not just a put a splitter in and tap into this.?? and if so which lines do it tap into? attached pics of the set up I have.. any help is appreciated
I assume your loader is a factor install. If I am correct, the FEL valve's power beyond is already used to feed the 3 pt hitch.
You cannot just use a splitter. You have an "open center" hydraulic system and the high pressure oil will just take the simple low pressure path back to the reservoir and nothing on the PB circuit will work including that which is now working.
Your tractor looks to be new.
I give many people hydraulic advice. Some don't follow it having found a youtube expert. Usually they are back with expensive broken components from dead heading a pump or blocking a relief valve path to the tank.
Either invest in the proper equipment, i.e. the rear remote, or buy a backhoe which has its own pto driven pump.
Here is an example of a youtube expert's handiwork.
Later he had to come back to youtube and post a video explaining his mistakes.
This photo is of a part for an older tractor which no longer has this part available.
A second with a hose connected wrong and the part was destroyed.
With hydraulics there is no "lets just try it and see what happens."
Dave
M7040
