Hydraulic Question
   / Hydraulic Question #1
HeartBeetsFarm
Berkley, MA
Branson/3510
I have a Deere 5065E with one set of rear remotes. I currently use it mainly for a hydraulic top link, but I also use it to a run a plastic mulch winder. However I have to hold the lever down to keep the fluid flowing. I recently purchased a new root digger and will be using the remotes for the same purpose to move the chains. It gets a little old holding down the lever, but its not a big deal.
Should I be looking to add another set of remotes or is it fine to use my current set up? If adding another set, which type?
Thanks in advance.
   / Hydraulic Question #2
You're probably better to add another set of remotes so you don't have to constantly change between top link and implement.
Probably a remote with detent function. The lever will stay in position in whatever direction you choose.
Or one with spring return, like the one you have, and just use a bungee cord to keep pulling the lever.
   / Hydraulic Question #3
When I added remotes, I put on two without detents for my top and tilt cylinders and a third with a detent to run a post pounder. My application is similar to yours, when I'm using the pounder I want the remote valve to stay on all the time because the pounder has a separate valve at the operators station to make the ram go up and down. As the other poster said you could just use a bungee cord, that works too.
   / Hydraulic Question #5
Is there such a thing as too many remotes? :D I have three on my Ford.
A detent kit can be added to most valves. I've seen them sold separately. They replace the rear cup on a valve body.
PENDING SELLER CONFIRMATIONS (A51219)
PENDING SELLER...
2009 Ford F-250 Pickup Truck, VIN # 1FTSX21Y49EA41686 (A48836)
2009 Ford F-250...
John Deere 5090E Tractor with Loader Prep Package, 2 Rear Remotes, Warranty Until 2028 (A51039)
John Deere 5090E...
2008 FORD F-450 (A50854)
2008 FORD F-450...
2005 Big Tex 10PI 16ft. T/A Utility Trailer (A49461)
2005 Big Tex 10PI...
2006 John Deere 650J LGP Crawler Tractor Dozer (A50322)
2006 John Deere...
