Hydraulic mower question
   / Hydraulic mower question #1
handirifle
Veteran Member
Central Coast of CA
Massey Ferguson 1010
In searching for a suitable mower for my 3 acres, during the earlier months of the year, it seems 4WD is almost a necessity. I have a 4WD tractor, but it has R1 tires on it and I spend more time unsticking it with my truck, than it's worth, at least as a mower.
I have a 20hp riding mower, but being the typical 2WD (or one as is REALLY the case) it can and does get stuck in some of my marshier areas.
I have priced the Kubota BX line, and new ones are out of my reach, and used ones almost are, I just can't make myself pull the trigger on one, not yet anyway. If I went that route I would replace the riding mower and my tractor (MF1010) with just one unit, not a bad way to go really.
BUT, I got to thinking (this is usually where I start getting into trouble) about the fact that no one makes a real 4WD riding mower, that is priced under 10K. seems pretty absurd to me. Plus I am pretty disgusted with all the belts one has to keep up on with a typical riding mower (I know the Kubota uses drive shafts, just bear with me)
I was wondering if one could convert a garden tractor, of say 20hp or more (gas), to run just hyd motors, that drove front and rear wheels, and the mower deck as well. Speeds need only be up to 6-8mph top, but torque needs to be high. For the blades, they would need speed and torque. This fantasy mower would have a deck in the 52-54" range also.
I understand how hydraulics work, and their basics, but would have no idea what motors I'd need, or flow rates. I see motor prices are all over the place.
Would one motor drive the rear alone, or would you need two. I know the front would most likely need one per wheel, as that seems simpler than setting up a differential.
Is this idea even feasible? Why haven't manufacturers gone this route before?
   / Hydraulic mower question #2
Have you looked at the PowerTrac, it has 4 wheel drive using hyd motors. The machines run from small to large slope mowers. Here is the web site.
NEW
Thanks JJ
After looking at them, they're not a whole lot less than the Kubota, and that's a gas engine model, at $8500. Thanks for the link though.
   / Hydraulic mower question #4
Hydraulic hasnt been done in consumer mowers because of cost and complexity.
However is is extremely common on commercial equipment.
probably the cheapest and easiest way to do this would be to find a old used 4wd fairway mower and adapt the complete system to your vehicle. Even a couple old used triplex's which are easier to find would work as a parts source.
Piecing together a system from off the shelf parts will be $$$$
Yea it looks like its way more than I had imagined.
   / Hydraulic mower question #6
You would need a lot more engine than 20 hp to drive 2 axles and a mower deck (of enough size to be worth the trouble) with hydraulics. I am in the process of building a 4wd mini tractor from scratch and am planning on driving a 72" deck hydraulically. I am using a 100 hp subaru car engine because I couldn't find any engines big enough to drive the hydraulics that didn't cost a fortune. Not for the faint of heart and its not something you can just slap together.
2012 FREIGHTLINER CASCADIA (INOPERABLE) (A50854)
2012 FREIGHTLINER...
2021 Cat D5 LGP Dozer (RIDE AND DRIVE) (A50774)
2021 Cat D5 LGP...
STOP!!!! PLEASE READ ALL TERMS BEFORE BIDDING!!! UPDATED TERMS!! (A50775)
STOP!!!! PLEASE...
71050 (A49346)
71050 (A49346)
2015 Freightliner Ambulance (A50323)
2015 Freightliner...
Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
Bad Boy Outlaw XP...
