Richard
Elite Member
- Joined
- Apr 6, 2000
- Messages
- 4,972
- Location
- Knoxville, TN
- Tractor
- International 1066 Full sized JCB Loader/Backhoe and a John Deere 430 to mow with
I've got a 15' hydraulically powered flex-wing mower. 4-5 years ago, rebuilt all the motors that operate the blades (and the pump which hangs off the PTO on a speed increaser). Note that the outer two sets of blades are on the same hydraulic circuit. Fluid goes from the pump to the right side motor (call it passenger side). Fluid exits that motor and goes over to the left side motor. Center motor is on its own circuit from the pump.
I've noticed recently that if I get into tall/dense growth, the right side will tend to bog down while the center and left side will still cut much, much better. Given the right side motor is first in line and the left blades, cut like a bandit I deduce the motor itself might be weak and/or, there is a drain that goes from the motor into the fluid tank.... Not being a hydraulic expert, I suppose this could be leaking some pressure off (but why then does the left side still cut like a bandit!)
Here's the schematic of the right side motor. If I yank it off again, where might I focus my attention, presuming that I don't find broken vanes or O-rings laying about in there. This strikes me as such a simple design, AND the unit down stream works MUCH stronger, it seems this HAS to be getting the pressure yet, why is it bogging down when the second isn't.
I might add, when bogging down, it will still cut, say half of what's under it but some of it just gets laid down, run over and stands back up.
Also.... blades are sharp enough so I can't blame the blades.
