Hydraulic hose size for small loader?
   / Hydraulic hose size for small loader? #1
James Eric
I am working on adding a loader to my Garden Tractor. This is a 300-500 pound class loader. A friend suggested that I use 3/8" lines. However, the ports on my cylinders are 1/4". Does it matter if I use 3/8" or 1/4" lines to the cylinders?
The pump is set to at 3.31 GPM but I can go higher with a smaller pulley.
Thanks,
James
   / Hydraulic hose size for small loader? #2
You can use either size hose, the 3/8 fittings and hose will cost more.
Do the 1/4" ports at the cylinders limit my flow or is there a benefit to having the 3/8 hoses going into the cylinders?
   / Hydraulic hose size for small loader? #4
with the 1/4 lines you are right at maximum recommended velocity which will work. the 3/8 will also work well with less of a pressure drop but probably won't be noticeable.
I had hoped to use 3/8" lines and a higher rpm for a faster response but it looks like the 1/4" ports mean I should stick with the lower RPM and 1/4" lines.
   / Hydraulic hose size for small loader? #6
Rpms only determines volume, and the cyl will work faster with more GPM.
The current GPM will max out the 1/4 lines. If I increase the GPM and use 3/8" lines will I get a faster response even with the 1/4" ports on the cylinders?
   / Hydraulic hose size for small loader? #8
1/4" NPT ports are equal to 3/8" ID lines. I try never to use 1/4" lines on anything other than pressure gauge lines. CJ
   / Hydraulic hose size for small loader? #9
i don't think you're going to need to increase your rpms over using the 3/8 line it will work well as the ports match your hose id. and if you do throttle up you're not forcing more oil through maxed out lines.
Thanks everyone. I will go with the 3/8 hoses. It is only a few dollars for the entire set.
James
2015 FREIGHTLINER CASCADIA DAYCAB (A50854)
2015 FREIGHTLINER...
2016 CHEVROLET SILVERADO 2500 HD CREW CAB TRUCK (A51243)
2016 CHEVROLET...
John Deere 7130 Loader Tractor (A50514)
John Deere 7130...
(INOP) CATERPILLAR 259D SKID STEER (A50459)
(INOP) CATERPILLAR...
E-Z TRENCH GROUND SAW (A51244)
E-Z TRENCH GROUND...
2021 FORD F-150XL CREW CAB TRUCK (A51406)
2021 FORD F-150XL...
