hydraulic fluid getting into engine on farmpro 2425
   / hydraulic fluid getting into engine on farmpro 2425 #1
Red861
Attica, IN
Ford 8N, Ford 601 Workmaster, Farmall 706, Farm Pro 2425.
I fill the hydraulic fluid, start the tractor and the fluid fills the crankcase somehow to the point that it runs out of the engines vent tube. Any Ideas?
   / hydraulic fluid getting into engine on farmpro 2425 #2
got a qd that unseated and / or otherwise blue the shaft seal out of the pump. it's an engine drive. so once shaft seal goes. it puts oil inthe engine.
if there is a blocked qd or one that didn't fit up.. it deadheads the pump.
i've seen farm pro pump setups with wd right after the pump and BEFORE the relief valve.
what genius came up with putting a 'deadheader' inbetween a pump and it's relief.. i'll nver know. deffinately a designed to fail setup IMHO.
anyway.. check that.... it would be at the very top of my list of faults to check....
post back what ya find.
Okay, thanks. not sure what qd or wd means but I'll check the pump seal.
   / hydraulic fluid getting into engine on farmpro 2425 #4
qd = quick connect/disconnect.
might be time to brush up on some tractor lingo too.
you'll see lots of it / use lots of it.
farm pro are hands on machines .
you'll either be doing plenty of maint.. or having someone do so.
not bad machines or anything. they will just require some hand holding.. etc.
3000 Gallon Black Poly Water Tank (A49461)
3000 Gallon Black...
2021 Caterpillar 304E2 Mini Excavator (A50322)
2021 Caterpillar...
20Yd Roll-Off Container Dumpster (A49346)
20Yd Roll-Off...
2015 FORD F750 BOX TRUCK (A51219)
2015 FORD F750 BOX...
2012 STEPHENS 220BBL CRUDE OIL TRAILER (A50854)
2012 STEPHENS...
4 1/2 150G DRILL STEM 358 JOINTS (A50854)
4 1/2 150G DRILL...
