handirifle
Veteran Member
Here I go thinking again, I usually end up either embarrassed or confused, but here goes.
Have been toying off and on, about building some sort of vehicle to cruise around on, while on the property. My land isn't big or steep, but I do have a few uses for it. Also being thrifty (spelled cheap) I thought I could build one, if and when the pieces showed up real cheap.
It would be a sort of golf cart UTV type of rig, but before anyone suggests, I am not a fan of golf carts themselves, gas or electric. In my opinion, when I'm about to run out of power, it faster and easier to gas up than to charge up. The gas golf carts that start when you hit the gas, I do not like either. Yea I know, I'm picky, but hey, it's my idea.
What came to my mind, last night, and the reason it's posted here, if wondering how efficient a hydraulic drive would be? I could use a 15-20hp engine, to drive a hydraulic pump, and use that to drive the vehicle. Reverse and forward ought to be a simple affair, but what I do not know is what kind of speed I could expect. I suspect the thing would be easily under 1,000lbs and a top speed of 10-15 would be plenty, I just do not want a crawler.
Thoughts?
Thoughts?
