Hyd. Toplink chattering?
   / Hyd. Toplink chattering? #1
Bob_Young
Veteran Member
North of the Fingerlakes - NY
Ford 4000; Ford 2000(both 3cyl.);JD40; 2004 Kubota L4300; 2006 Kubota B7610; new 2007 Kubota MX5000
I've had the CCM hydraulic toplink on my L4300 several months now and think it's great. Just started using it with my new Woods 65" Boxblade and noticed a problem.
When I go to extend the toplink while holding the BB off the ground with the 3pt. hitch, I hear a deep vibrating groan that can be felt as well as heard. This doesn't occur if I extend the link while the BB is on the ground or while retracting the link, BB on the ground or not.
I figure the weight of the BB is causing the cylinder to try to overrun the hydraulics and the checkvalve is rapidly opening and closing to prevent this....and that the checkvalve action is the cause of the groan. If I've got this right, there's not much that can be done about it; but I'm wondering if someone else has a better answer. I did a search but didn't find anything...may not have used the right terms.
So, has anyone else experienced this? If so, Are there any solutions other than simply lowering the implement to the ground before extending the link?
Thanks.
Bob
Thanks.
Bob
   / Hyd. Toplink chattering? #3
</font><font color="blue" class="small">( I figure the weight of the BB is causing the cylinder to try to overrun the hydraulics and the check valve is rapidly opening and closing to prevent this....and that the checkvalve action is the cause of the groan. )</font>
Not quite sure what you mean by this. A pilot operated check valve will not open unitl the pilot (cracking) pressure has been reached, usually 500 psi on those CCM check valves. Since the cylinder works correctly when the BB is grounded I don't think the cylinder or the check valve is the culprit.
I have seen cylinders struggle to move very lightweight objects and the problem turned out to be geometry related whereby the cylinder was trying to push a pinned implement and all the cylinder did was push against the pin instead of causing the pin to rotate.
I have a CCM hydraulic top link and have used it with a BB and a snowblower, which are heavy implements, and never experienced what you are.
   / Hyd. Toplink chattering? #4
Move the tractor end of the HTL to the other set of holes in the toplink bracket. See if that changes anything.
//greg//
   / Hyd. Toplink chattering? #5
Mine has done the same only if the implement is lifted up high by the 3pt. Does not do it under normal operation, and I use it a lot. I just figured it was straining when the geometry changed with the boxblade lifted high for transport. I normally dont even adjust the hydraulic top link in that position, but noticed it after hooking it up and trying everything out. I'll have to give a try what Greg mentioned to see it it makes a difference.
Thanks for the idea, greg. I'll give that a try.
3RRL: I get the GROAN whether the BB is lifted high or just barely being supported by the hitch (part of BB weight supported by the ground). The only time it doesn't groan on extension is when the full weight of the BB is on the ground.
Don't think it's struggling to do anything Mad, but there could be a geometry issue. The weight of the BB would naturally pull the toplink to full extension were there no valving in the hydraulic circuit to prevent it. When the weight of the BB is fully on the ground, the toplink extends and tilts the BB easily and quietly. With weight on the lower links, something could be binding that doesn't when the hitch is floating.
I used the toplink over the winter with a rear blade for moving snow. Never had this happen on that implement. But then I always had the blade's skid shoes on the ground and used the link to set some clearance between the blade edge and the pavement.
Well now you guys got me thinking. I might try some different settings on the telescopic stabilizers as well. I set 'em for no sway at hookup ; they might be binding when the hitch is supporting weight.
Got Pat's EZ hitch on the ends of the lower links. Those things don't rotate to align with the pins like the ball ends do. Might need to adjust yaw and roll on those....the racket could be coming from the pins. If that were the case, you'd think it'd groan on cylinder retraction as well.
Just knowing that this isn't common is a great motivator.
Thanks.
Bob
   / Hyd. Toplink chattering? #7
Bob,
My CCM toplink does the same thing.
Sounds like you're moving something that has been sitting a hundred years and creaks...
Once it is warmed up and used it seems less, but even lowering it is sometimes a little jerky.
I think it is due to the geometry, where at many multiple points the cylinder is rapidly pushing, then holding back as the BB rotates under minimal strain (slight binding due to geometry). It pushes when the BB binds, then holds when the BB is falling.
I think it may also be made worse by the low flow volume of my included rear remotes on my Mahindra 3510. This is made even worse in that I am usually adjusting when at low idle, between operations, in turns, etc.
If you learn anything else, let us know.
-JC
   / Hyd. Toplink chattering? #8
It may not be top link per se.
I had the same problem on a Bush Hog box blade. It was a good heavy unit, but when pushing it chattered horribly at times. Adjusting the angle helped, but that hurt productivity.
On close examination, the steel straps for the top link needed gusseting or should have been made from heavy "L" shaped or box shaped members instead of straps. When pulling it was fine, but when pushing the straps bowed just a little bit. It was a borrowed implement, but if it were mine, I would have welded some big steel to it. /forums/images/graemlins/tongue.gif
   / Hyd. Toplink chattering? #9
</font><font color="blue" class="small">( the straps bowed just a little bit. It was a borrowed implement, but if it were mine, I would have welded some big steel to it. )</font>
The straps are supposed to bend. If there wasn't some built-in flex, cutting heights would be erratic - and something would (will) end up breaking. Sooner more likely than later.
//greg//
   / Hyd. Toplink chattering? #10
See attachment. Are these the straps that you are talking about or have I missed something?
1986 CATERPILLAR D6H HI-TRACK CRAWLER DOZER (A51242)
1986 CATERPILLAR...
2004 Ford E-250 Cargo Van (A50323)
2004 Ford E-250...
2015 Terex PowerScreen TrakPactor 320 Crusher (A50322)
2015 Terex...
2016 CATERPILLAR TL642C TELESCOPIC FORKLIFT (A51242)
2016 CATERPILLAR...
Zero Turn Mower (A48082)
Zero Turn Mower...
2022 John Deere 325G Skid Steer (A50657)
2022 John Deere...
