Hyd drive unit question
   / Hyd drive unit question #1
handirifle
Veteran Member
Central Coast of CA
Massey Ferguson 1010
If one were to make an Argo type 4 passenger, 6x6, using a small diesel engine and 2 Hyd motors for drive system, could everything be sized (pump, motors etc) and geared to provide a top speed of 20-25 mph?
Seems like hyd drive is the best way to run one of these, to make it steerable.
   / Hyd drive unit question #2
Sure, you just have to match up l the HP, pump displacement hyd motors ,diameters of the tires, and hyd motor torque, etc.
You would probably want one motor per wheel, as in this from Power-Trac.
UV Class
http://power-trac.com/pdf2008/508/UtilityVehicleUV051508.pdf
Two large hyd motors running chains to all the wheels would work also.
Yea the 2 large motor idea was more what I had in mind, that way it would be easier to set the final gearing.
3-Point Box Blade (A50860)
3-Point Box Blade...
Lot of 3 Dell Desktop Computer (A48083)
Lot of 3 Dell...
2004 Toyota Avalon XLS Sedan (A50860)
2004 Toyota Avalon...
2803 (A50460)
2803 (A50460)
2018 Dodge Ram 5500 Bucket Truck - 4x4, Versalift VST40, 45FT Reach, Dakota Line Body (A51039)
2018 Dodge Ram...
2015 Isuzu Sewer Jetter Truck (A49461)
2015 Isuzu Sewer...
