Husqvarna YTH22K42 Lawn Tractor Not Starting
   / Husqvarna YTH22K42 Lawn Tractor Not Starting #21
Sometimes my PTO is locked on my YTH2448 and I cant start it-I get nothing. Have to reset it a couple times. 600 hours so 4ar.
   / Husqvarna YTH22K42 Lawn Tractor Not Starting #22
Went to start it tonight - nope. But thanks to tomplum a little tinkering with the brake switch and we were back in business. Thank you SIR.
As per my #2 posting: "Is the brake set?" ;)
First thing I did was check the brake. Set it, then reset it then set it so hard I was afraid I might break something. Got under the tractor to see if I could see a problem with the switch contact and it looked fine. At that point I thought, well it can't be the brake. The last time it didn't start (now knowing it can't be the seat switch) I pulled off the side panel and disconnected the brake switch, and gave the wires a good going over - at that point it started. Not sure yet if it was a wiring issue or if I have to replace the switch. Didn't miss the #2 post - just went full circle on it...
   / Husqvarna YTH22K42 Lawn Tractor Not Starting #24
Going in circles never end's well. o_O
2010 Club Car Golf Cart (A56859)
2010 Club Car Golf...
2017 DODGE RAM 3500 DUALLY (A58214)
2017 DODGE RAM...
2016 PETERBILT 579 DAY CAB ROAD TRACTOR (A54756)
2016 PETERBILT 579...
GRID SHAPED BUCKET FOR MINI EXCAVATOR (A58216)
GRID SHAPED BUCKET...
JMR 40" Mini Grapple (A57149)
JMR 40" Mini...
2013 TEXAS PRIDE LAY FLAT HOSE TUGGER TRAILER (A58214)
2013 TEXAS PRIDE...
