HST vs shuttle
   / HST vs shuttle #192
I would only buy a Hydro if it was a small tractor (<20hp) to be used mostly for a belly mower. There is a real loss of power (not degrading, but just not as much power as a manual or SS) with the hydro.
In fact, I just ordered another tractor to replace my brand new (10 hours) tractor that came with a hydro. The hydro isn't the only reason I'm trading in this new tractor, but I was not impressed with it.
My friend has a 20 HP machine with the hydro and it works well for that small machine.
Another note, if you are doing work with a front end loader, it seems that a hydro would be best, but I found that the bouncing around involved actually led to less control with the hydro as your can't use your foot to support yourself.
Just my 2c.
Enjoy.
   / HST vs shuttle #193
Not reading the whole thread and guessing this probably late but I will add my 2cents. I WILL ONLY HAVE AN HST FROM NOW ON!
I have a 30hp Kubota HST and it does everything I ask it fine. The convenience is well worth any lack of power, which I have not noticed (2004 model).
As to previous post to mine, on the Kubota you can use your foot to support yourself. I presume the intended operation of the pedal is to put your whole foot on it and rock it. I don't like that at all, I put my foot on the floor and push down like a gas pedal for forward then use my toe to lift it back up for reverse this is very easy and should be the way it was designed.
   / HST vs shuttle #194
I've found it very useful to be able to creap back and forth while keeping the PTO up at 540 with the HST, all while increasing/decreasing travel speed. To my knowledge (and I'm sure I'll be corrected if I'm wrong) in order to change speeds on a shuttle transmission you need to shift gears if you want to keep RPM at a constant 540. In other words, I don't think you can change direction and increase/decrease ground speed while maintaining 540RPM's on the PTO using a shuttle? Am I understanding this correctly? I know I can't do that on my powershuttle tranny in the JD 410 backhoe, but it's not a farm tractor either.
   / HST vs shuttle #195
Figured I would pile on to this old, long thread:) I have two identical Kubota G series, one HST, one geared. I definitely prefer the HST for convenience and the wife/kids find it much easier to drive. The HST does whine under heavy load but I never encounter this while mowing/blowing. The gear does not whine at all and appears to be more efficient by my super scientific methods (the HST gets freakin hot when working hard). It has a fan though and I change the oil/filter on schedule and have never had an issue. Also have an old Ford loader tractor, geared. It is cumbersome to shift, foot throttle, loader up, tilt, down etc but is way better than no tractor. Oh and I have seen very little mention of creeper gears for a geared transmission. In my mind mandatory for fine loader work.
   / HST vs shuttle #196
Mowing the lawn or brush mowing with my gear shuttle shift, to speed up/slow down I just use the foot throttle while staying in the same gear. Or I can change gears for different speeds.
Same for forward/reversing while mowing. I throttle down with the foot throttle, change directions and speed back up.
Does the RPM's remain a constant 540 PTO RPM= NO.
Has it ever been an issue for me while mowing = NO. Still mows just fine. I use my tractor to mow the lawn every week this way and it mows just fine.
   / HST vs shuttle #197
When I used to brush hog with our IH2500b I kept the engine speed at the RPMs that indicated 540RPMs on the PTO. If I started bogging down, I could do one of two things.... I'd just let up on the pedal and maintain the RPMs, or I could step on the gas pedal and maintain RPMs. But sometimes, even at full gas, I'd be losing some power in really thick stuff, so just letting off the pedal was the method I chose more often.
   / HST vs shuttle #198
...I throttle down with the foot throttle, change directions and speed back up.
Does the RPM's remain a constant 540 PTO RPM= NO....
Thanks for confirming that Vince, that's how I understood it but I wasn't 100% sure. :thumbsup:
   / HST vs shuttle
After a year of looking at different brands and models of tractors I have finally pulled the trigger and bought a 6065 Mahindra power shuttle w/cab. Of all the tractors I looked at, set on, and test drove around the lots I really liked this one the best. The lay out of all the controls are the most comfortable and user friendly to me of all the tractors I looked at. I'm having them fill the back tires with fluid to help with stability when using the loader and when on the slopes on the farm. With the HST that I test drove I did like some features about them but in the end even the wife said she didn't like driving them as much as the power shuttle. Now we are waiting for the call for it to be delivered to the farm. It will be a couple of week as the are building the tractor to my specs and shipping it to me from there. I cant wait to get all the backed up projects going that I have been needing a tractor to do. I'm like a kid with a new toy as in I'm making a list of all the projects I need done and in what order I'm going to start doing them. I will try to post a picture of it with all the attachments I got with it once it comes in.
I would like to thank everyone for your input on this thread as your advice, experience, and opinions were all taken into consideration while I was looking at all the options I had available.
   / HST vs shuttle #200
Congratulations. I like my power shuttle. Pics when you get it please.
2023 John Deere 5105M (A53317)
2023 John Deere...
2011 GMC Yukon XL Denali (A56859)
2011 GMC Yukon XL...
2020 JOHN DEERE 85G EXCAVATOR (A52707)
2020 JOHN DEERE...
Year: 2016 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A55853)
Year: 2016 Make...
2016 Ford Explorer AWD SUV (A55853)
2016 Ford Explorer...
(APPROX.108) UNUSED 2X4X10 PREMIUM GRADE LUMBER (A57192)
(APPROX.108)...
