HST vs shuttle
   / HST vs shuttle #171
I wondered about forklifts.... I've driven quite a few over the years. The smaller ones just had a lever on the column for forward-N-reverse, a brake pedal and a drive pedal. The largest ones (something like 20-30,000# lift) had a forward and reverse pedal, and a brake pedal, and that's it.
One had a 4 speed and a clutch.... that one sucked! :laughing: We had to load airplanes with a clutched forklift.... with no rubber pad on the clutch pedal, just bare, shiny metal. Caused some problems in the rain! :eek:
   / HST vs shuttle #172
We’ve got an ancient Clark with a clutch and yea it sucks. We’ve got a Cat that’s HST which I don’t like. It’s got the forward and reverse treadle pedal on the left and the gas pedal on the right and the brake in the middle. With no throttle set it requires constant use of both feet to operate. I like the ones with the shifter on the steering column a lot better with just a gas pedal and brake.
   / HST vs shuttle #173
I don't care for one-foot treadles. My little Power Trac PT425 has a treadle, but it's mounted in the center, so right foot forward and left foot reverse. No brakes (does have a parking brake). I like it a lot. It's very easy to position on slopes and tight quarters. There's no time delay moving your foot from a right to left pedal. It all becomes a quite natural feel the more you operate it.
   / HST vs shuttle #174
I don’t have any problem with treadle pedals on tractors, but this forklift one is left foot operation only while requiring right foot to control RPMs.
   / HST vs shuttle #175
Way too much focus on the treadle/left-right pedal options. You get used to what you have in my opinion.
   / HST vs shuttle #176
Yep... until you jump on another machine and it's different and you put an air-hose pass-through port in the side of your garage.... :rolleyes:
:laughing:
   / HST vs shuttle #178
Some of us have a lot more than ONE tractor, I don't like them all being different!
SR
   / HST vs shuttle #179
Yes, growing up working with lots of different machines teaches a person to tailor a set of reflexes for each machine.
So different controls were not a problem for those on the land, and still aren't. I could see it being a problem if there were identical machines with different controls, but that would be rare enough to be a warning all by itself.
But that's not to say that we kids didn't notice that everyone liked some control layouts better than others. We all agreed that JD controls were always a pleasure and a favorite. Summer time was harvest time and the days were long. Late at night laying in our cots in the barn we would talk about things like the new machines we had seen and generally wonder about the world. This was back in the 1950s & 60s. We knew about factories of course from pictures in school books, but nobody had ever been to one and we had only a vague idea of how they worked. About the people in them, we knew nothing. In fairness, we agreed that it was apparent that the folks in factories didn't actually know much about farming either.
Regardless of the kind of machine, the best were way ahead of the rest; it wasn't even close. JD was lots better at knowing what people on the land were looking for back then. We could tell that JD must somehow put more & better thought into placing the controls. What we couldn't figure out is why other brands didn't do the same. I think we concluded that it must be ignorance of some kind.
Gleaner/Baldwin was one of the worst. We concluded that in a lot of machines all the controls were awkward because the folks who made then were ignorant. They could hardly help being so, since as far as we ever knew nobody from any company ever asked the people who actually ran the machines how they liked the control layout.
But maybe JD did just that & if so maybe it explained why they were better. Or maybe the JD control person just happened to be an old farmboy of standard shape and size.
Now I haven't looked at control layout in years, and my machines are old enough that they don't count.
In fact, there may be other machines today that are even better than JD. I haven't looked at JD either since about the time they went to plastic fenders.
But I wonder, does JD still have a noticibly better control position layout than the other makes?
rScotty
   / HST vs shuttle #180
When I was looking at compact tractors back around 2001, I had it narrowed down to a John Deere 4100HST, a Kubota BX2200, a New Holland TC21D, a Cub Cadet 7205 and a Power-Trac PT425.
The steering wheel on the JD was literally down between my legs. I didn't have enough room to sit on it and operate it comfortably. Arguably, the best ergonomics were on the NH TC21D. Man, that thing was a very, very comfortable machine to operate. Everything just seemed to be in the right place. The others had some issues I can no longer recall, and I ended up making my decision on the Power Trac for a variety of reasons. It had the most checks in the pros column on my pros and cons list.
Anyhow, my view of where things should be and how they should work is not always the best for anyone else, so as always, the best advice is to sit on as many machines as possible. Start them up, drive them around, do a bit of work with them, and see if they are a good fit for you.
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A56858)
2018 Ford F-150...
2019 KUBOTA U35-4 EXCAVATOR (A52706)
2019 KUBOTA U35-4...
2009 Kubota RTV900 4x4 Diesel Utility Cart (A55851)
2009 Kubota RTV900...
UNUSED PABREAK GCC56-2 PRONG HAY SPEAR (A57193)
UNUSED PABREAK...
Prime 452 (A53317)
Prime 452 (A53317)
2014 MOROOKA MST3000VD CRAWLER DUMPER (A52707)
2014 MOROOKA...
