Howse Dirt Scoop model ES30
   / Howse Dirt Scoop model ES30 #1
Sackett2
Platinum Member
Eugene, Oregon
Montana 4344HST
Are they a usefull tool? found one on Craigs list for 100$.
Thinking it would have some advantages over a FEL. Opinions?
   / Howse Dirt Scoop model ES30 #2
my 2cents:
Have a 24" dirt scoop that I used on my last tractor that didn't have a FEL and found it very useful. Got a lot of work done with that little guy. Now I have a tractor with a FEL and it's been on the tractor once. Thought it would penetrate the hard clay I was tring to dig better than the FEL, it didn't. Made a tooth bar for the FEL and haven't touched the dirt scoop since.
I have been eyeing the bucket off of it as the start of a grubber bucket though:D
The jungle has almost reclaimed it.....
   / Howse Dirt Scoop model ES30 #3
I have no FEL and haven't used my scoop much either. The times I did I was moving some dirt for a flower bed, it worked fine.
For $100 just get it and you'll have it.
   / Howse Dirt Scoop model ES30 #4
Well worth the money. I used mine a great deal prior to having an FEL. Not great (but can be done) for digging in hard soils but very useful for moving any loose material.
   / Howse Dirt Scoop model ES30 #5
It is worth $330 new. Handy for working in tandem with your FEL if you need t move a lot of dirt or sand. Load both at the same time for long distance transport. For short distances, a box blade would probably be better and with the scarifiers, likely dig much better. It should dig ok in the Lake Livingston clay if the top link is adjusted correctly. I just depends on what you plan to do as to which implement is better.
I would think that if it doesn't work for your purposes, just relist it on Craigslist and get your money back.
   / Howse Dirt Scoop model ES30 #6
I once dug a small pond and a ditch with one behind my 8n ford and a JD1010. Once you get the angle right it will dig just as good as a loader bucket. I really don't see any advantages over the loader but, for $100 I would get it just to have it. Use it for rear counter weight.
thanks, messaged the guy- I can sneek off wed to get it, the wife won't be home. I can hide it in the tall grass
2009 International Ambulance (A49461)
2009 International...
Vacuworx Vacuum Lifter Pad (A50860)
Vacuworx Vacuum...
1993 Ford F-350 4WD Ambulance Truck (A50860)
1993 Ford F-350...
2024 TOFT 1550 Hydraulic Breaker (A50860)
2024 TOFT 1550...
1989 Freightliner FLD120 (NEW CAT 3406A, NEW REAR ENDS, CLUTCH) (A50397)
1989 Freightliner...
2019 Ford Explorer AWD SUV (A48082)
2019 Ford Explorer...
