How to test a CV joint?
   / How to test a CV joint?
I've owned Japanese trucks with independent front suspensions that did not bind at all. Our Late 80's Chevy S-10 Blazer had independent front and no binding or bucking. So it can be done.
   / How to test a CV joint? #12
Usually it's U joints that have a tendency to bind exspecially on tight turns. CV joints are a much different design with smoother operation.
Solid front axle usually has U-Joints. Independant usually has a CV joint.
   / How to test a CV joint? #13
I,ve got a 2008 Ford F150, and was getting some weird binding, clunking, when turning the steering wheel.
I found the problem to be dry joints on the steering column, down low near the steering box.
Some good spray lube got them loosened up, and the noise disappeared. Now I do that lube procedure each fall and spring.
If you find that your CV joints are good, maybe do a quik check in this area.
CRAFTSMAN TABLE SAW (A54757)
CRAFTSMAN TABLE...
54" FORKS (A57192)
54" FORKS (A57192)
2024 Deere 335P (A53317)
2024 Deere 335P...
70pc. 12ft.x 3ft. Black Metal Roof Panels (A55758)
70pc. 12ft.x 3ft...
3pt 5' Mower (A56469)
2015 SkyJack SJ86T 4x4 86ft Telescopic Boom Lift (A55973)
2015 SkyJack SJ86T...
