How to replace oil seal on the driveshaft Yanmar YM2210 ?
   / How to replace oil seal on the driveshaft Yanmar YM2210 ? #1
piotrbpm
Hi experts Model YM2210, kicked me the honor to exchange oil seal on the driveshaft.
Unfortunately, the exchange is not as easy as the model YM2000
Photo No. 1
The Japanese decided a little difficult from the viewpoint of simple operation.
To remove the driveshaft No. 2 need to unscrew the securing No. 1.
To get to the gear you need to unscrew the cylinder together with the lift arms, distributor, etc ... (I deduced this from the drawing but I could be wrong)
I thought that you would unscrew the lid rear PTO and to secure No. 1 to get through a gap image 2
With the removal of the lift declaration is a lot more work, plus I had to disassemble the freshly electrical installation, but will not be out then I will have.
Maybe some of the holders had this problem? or it can repair the rear axle?
Not until the end of these photos can be inferred if the gear is No. 3 in the rear axle housing (casting), or may be in the housing 5 and disassembly must be carried out by removing the entire enclosure No. 5
If you have any suggestions gladly read a
Regards Peter
   / How to replace oil seal on the driveshaft Yanmar YM2210 ? #4
Unfortunately, the model has a different solution YM2210, YM2200 and this case has already chained:)
OK, looks about the same to me. Don't know what "already chained" means.
Here is the post, unfortunately I do not know English so I look after the forums come to me with great difficulty. It is a pity that you did not write step by step how you do it, the interpreter result not clear goggles
I wonder if I could get out without removing the driveshaft bearing housing as it conducted a colleague in this thread.
In their model, have a cab and she supports the fenders, and the dismantling of the housing to remove the driveshaft need fenders...
http://www.tractorbynet.com/forums/yanmar/187445-rear-axle-seals-ym2210.html
   / How to replace oil seal on the driveshaft Yanmar YM2210 ? #7
   / How to replace oil seal on the driveshaft Yanmar YM2210 ? #8
from the pics..You are refering to the about axle seal. not What we call drive shaft seal
   / How to replace oil seal on the driveshaft Yanmar YM2210 ? #9
Sorry guys I have not been on for a while--life gets in the way of fun sometimes! :laughing: Sure California I will help if I can.
Cześć Piotr, Możesz napisać po polsku i ja mogę tłumaczyć żeby oni mogą rozumieć. Kolejny tydzień jestem zajęty ale kiedy mogę będę. Możesz pisać email do mnie też mike@solidrockpl.org.
Masz YM 2210 i od zimmering na WOM, czy mostek, olej pływa? albo co? Nie miałem czasu jeszcze żeby sprawdzić zdięcie z postami.
Mike
   / How to replace oil seal on the driveshaft Yanmar YM2210 ? #10
Thanks Mike!
We can probably help him - after we have a clear picture.
Your help is greatly appreciated. :thumbsup:
2019 CATERPILLAR 299D2 XHP SKID STEER (A51242)
2019 CATERPILLAR...
12in Backhoe Bucket (A51039)
12in Backhoe...
2025 K1912 UNUSED Metal Livestock Shed (A50860)
2025 K1912 UNUSED...
2014 INTERNATIONAL PRO STAR (A50854)
2014 INTERNATIONAL...
Headache Rack (A50860)
Blue Concrete Test Shed (A49461)
Blue Concrete Test...
