how to keep a knot from tightening too much when lifting something
   / how to keep a knot from tightening too much when lifting something #1
lamanated
Nova Scotia and Zephyrhills Fl
BX2360 JD 425 jd 455
wondering after prying for a half hr, if there is a way to tie a knot or keep a knot from tightening up so bad you cant get apart when you are lifting something,, We are using 2"straps..
   / how to keep a knot from tightening too much when lifting something #2
Have you tried a bowline?
   / how to keep a knot from tightening too much when lifting something #3
Put a piece of 1" PVC conduit in the center of the knot. It won't crush and will slide out reasonably easily. Then the knot will loosen up somewhat easy.
   / how to keep a knot from tightening too much when lifting something #4
   / how to keep a knot from tightening too much when lifting something #5
The running bowline has the anti-tighten quality of the bowline plus it will tighten up on whatever you tie it around.
thanks will try both bowlines might be hard with 2" straps though
   / how to keep a knot from tightening too much when lifting something #8
Knotting straps is really a no-no and doing so significantly reduces the lifting capacity of the strap, as far as I know.
That being said, you might try half hitches like shown in the above image, or a variation such as a cow hitch.
This knot slips and becomes a choker though. Perhaps this would not work for your application.
They are usually pretty easy to take apart after use though...
   / how to keep a knot from tightening too much when lifting something #9
If the strap won't allow using a bowline, try a "sheet bend" knot. The knot is used to tie large tow ropes together on ships and comes apart easily.
   / how to keep a knot from tightening too much when lifting something #10
I did not notice the intent to tie knots in a strap. I've never done that, it is a real bad idea. Get a rope and use rope knots. Or use a strap and slings as they are meant to be used. Or a chain.
2019 Ford Escape S SUV (A55853)
2019 Ford Escape S...
2013 Chevrolet Traverse AWD SUV (A56859)
2013 Chevrolet...
cummins generator (A56857)
cummins generator...
Enmark Z Spray (A53316)
Enmark Z Spray...
UNUSED 1RANCH 1RGPM GROUND PROTECTION MATS (A57193)
UNUSED 1RANCH...
15 TON GRAIN BIN (A57192)
15 TON GRAIN BIN...
