How to convert SCV valves?
   / How to convert SCV valves? #1
ovrszd
Epic Contributor
Missouri
Kubota M9540, Ford 3910FWD, Ford 555A, JD2210
Is it possible to remove the detents in one of these valves to eliminate the SCV feature?? If so can you explain the procedure? I can't seem to find a schematic of these Ford valves. Thanks in advance.
   / How to convert SCV valves? #2
The lovely Ford CCLS breakaways. I hated them back when I owned my 5610. Does this schematic help?
If I study it long enough Jim. I'm assuming theirs a detent ball/spring somewhere in there?
I've not used these yet, just bought the tractor. They're on a 3910. What did you dislike about them and is it changeable?? I will use these quite a bit so want them to be easy to use. Thanks Jim.
   / How to convert SCV valves? #4
It's been several yrs since my 5610 caught fire and burned but IIRC the hoses could be plugged in to breakaway correctly but the hyd oil would not flow through the couplers. My problem IIRC turned out to be a faulty flow control in SCV. I like the simple Pioneer couplers on my Ford 6700 I bought to replace the 5610 better than the CCLS couplers.
Maybe I oughta hook something up to them to see if they work properly before I worry about modifying them. I have little patience with a coupler system that isn't user friendly.
   / How to convert SCV valves? #6
Why do you want to remove the dent function? Other than the breakaways I really liked my 5610.
I plan to add TnT. Thought I wanted at least one set that didn't detent to move. Kinda hard to do small movements??
Misc Items (A50860)
Misc Items (A50860)
1 Avaya Conference Phone (A48083)
1 Avaya Conference...
2007 Amkus Rescue System (A50322)
2007 Amkus Rescue...
2017 Infiniti QX60 SUV (A48082)
2017 Infiniti QX60...
2014 New Holland T8.360 MFWD Tractor (A51039)
2014 New Holland...
2015 MACK GU713 WINCH TRUCK (INOPERABLE) (A50854)
2015 MACK GU713...
