How powerful is an 883 Sportster?
   / How powerful is an 883 Sportster? #41
<font color=red>And what COOL STUFF is available</font color=red>
Thats true. You could build a whole motor, and not use one OE part.
   / How powerful is an 883 Sportster? #42
You could build a whole bike, and never use a HD part! Amazing, but true!
In fact, you could go to Sturgis and assemble a whole bike with parts bought there... Maybe that's what Thomas was up to during this years trip/w3tcompact/icons/grin.gif
   / How powerful is an 883 Sportster? #43
You might check out <A target="_blank" HREF=http://www.nightrider.com/biketech/>http://www.nightrider.com/biketech/</A>
They have some engine buildups, with data.
That's a great website. I saw the engine buildup for the 81HP engine. I absolutely believe their dyno charts and info. Those look just like the dynojet charts that my software spits out. Also, those are the kind of parts I would expect you would need to make 1HP per cubic inch on a Harley. That is an impressive torque curve. Totally smooth flat power, right where you need it. I noticed that even their engine runs out of breath at 5800 RPM. That is really where a dyno run will help you have a faster bike. By running your bike you may find that you would actually be faster by shifting at a lower RPM than 6500. You can actually make a faster bike with no engine changes at all, by shifting it at the right RPM. Do you have those same heads on your bike? Is that $799 per head, or for both? On HD's website those heads list for $929, and I can't tell if that is per head or for a set. It looks like those heads employ bigger valves, diferent springs, and a higher compression ratio. I'll say it again, Harleys have cool parts available.
   / How powerful is an 883 Sportster? #45
/w3tcompact/icons/laugh.gif There were sure some great deals to be had tho..S&S,US Chrome,Frames-R-US etc.. /w3tcompact/icons/wink.gif
That was kinda presumptuous of me to be estimating what kind of power your bike makes. I don't know you or your bike. It's just that I talk to a lot of people who think you can add 25HP to a 55HP bike by putting on a set of pipes. If I thought Harley guys could get offended, I would apologize. /w3tcompact/icons/wink.gif
   / How powerful is an 883 Sportster? #47
Yes, the proper shift point is not necessarily at redline. I think you are right, a dyno could tell me more about the optimum shift point. I do find the power "feels" good at that 5500-5700 rpm.
That page has great info. I have refferred to it in the past.
My mod's are as follows:
Crane Hi-4 Ignition module, set full advance
S&S Super Carb(had a Mikuni HS40, but too many problems
Andrews EV27 cam
Screamin Eagle tips on stock cross over headers
50 thou shaved from stock heads, with high rpm springs and hi-po valve job
20 over bore for wear
I also swapped to a wide glide with a 21" on the front, but that doesn't affect dyno runs.
I have more compression than thier "stage-2". My cam has the same lift, but opens and closes earlier than the EV46 they use. My extra compression and valve job probably puts me in between the Stage-2 and Stage-3. So, the guestimate my mechanic and I have at about 80hp is probably reasonable, if maybe high by a couple ponies.
I had run a Crane 306 cam with a 2:1 Thunderheader. It ran wicked at upper rpms. The Thunderheader ran well, but was too loud. The Crane 306 came on at too high of rpm, ~3500. The stock header with tips and the slightly smaller cam puls stronger across the power band.
The Mikuni HS 40 ran great at top end, but had problems with casting ridges blocking the float, poor mileage, and nobody in the area who would touch or tune it. The S&S does not have the bottom end punch the Mikuni did, but is smoother across the rpm range. I also get better mileage.
It would be fun to throw a set of heads on it, but the $$$ go to tractor and property right now. My '84 heads are the least perfoming of the Evo heads, so I loose a bit there.
I charge $50 per hour on the dyno. I can set up and run most machines 3 times in a half hour. Why not stop in on your way to Daytona this spring? /w3tcompact/icons/laugh.gif
   / How powerful is an 883 Sportster? #49
Ahh. A discussion on Harleys, and someone brings up a Superhawk 996. Makes me feel all warm & fuzzy inside.
The sport bike guys say "that aint no sport bike, it's got a V-Twin."
The cruiser guys say "That aint no cruiser, look at all that plastic."
I believe only the Ducati guys truly understand.
...the pic is of my most recent family members.
543 (A52708)
543 (A52708)
SNAPPER ZERO TURN LAWN MOWER (A52708)
SNAPPER ZERO TURN...
JOHN DEERE 6500 HI-CYCLE SPRAYER (A52708)
JOHN DEERE 6500...
New/Unused CFG Industrial MH12RX Mini Excavator (A57453)
New/Unused CFG...
2015 Ford Transit 150 Cargo Van (A56858)
2015 Ford Transit...
Hydraulic spike driver (A56435)
Hydraulic spike...
