How much does a canopy add to overall height of tractor?
   / How much does a canopy add to overall height of tractor? #11
It varies with tractor model - but as an example, my R4 Industrials are about 4" smaller in diameter - so the axles are 2" lower than with R1 Ag tires. There are many discussions on TBN about R1 vs R4 tires, with pros and cons of both. R4's hold up better on pavement - and will do many jobs just fine. R1's give more traction - good for ground-engaging attachments like plows & harrows - also nice when pulling a haybine or baler on slopes.
If your barn opening is 103" and the tractor is only 97.2" on Ag rubber, there should be enough clearance - even with a canopy and tire chains. Are you expecting a buildup of ice to reduce the 103"? One of my doors is only 3/4" above the canopy when my winter chains are on. Works ok.
NEW 2022 Load Trail CH 83IN x 18FT Equipment Trailer (A51039)
NEW 2022 Load...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
2022 INTERNATIONAL MV607 26FT BOX TRUCK (A51222)
2022 INTERNATIONAL...
1990 Ford F800 7 Yd. S/A Dump Truck (A48081)
1990 Ford F800 7...
1955 FORD COBRA REPLICA RACING CAR (A51222)
1955 FORD COBRA...
2011 Kubota M7040SUD 68HP Utility Loader Tractor (A49461)
2011 Kubota...
