How do you remove turn signal switch on Boomers?
   / How do you remove turn signal switch on Boomers? #1
bnixon
Houston, Texas
TC33D / 7308 ldr 60" HD bucket
I am trying to remove the turn signal switch on my TC33D from the black plastic panel and need to know how the switch comes off. I assume that the switch handle (for lack of a better name) just pops off and a retaining nut is under it. But it doesn't seem to want to pop off? /forums/images/graemlins/confused.gif
Can anyone tell me how this comes off?
Thanks,
   / How do you remove turn signal switch on Boomers? #2
Re: Need help from someone with Class II Assembly Man.
Brandon, I think your switch is very likely similar to the Class III switch, so I'll tell you how it is assembled. On top of the switch, there is a decal with a large left-right (<-- -->) arrow. That decal extends over the center of the switch. If you lift the decal at the center of the switch, there is a phillips head screw holding the handle onto the switch shaft. It's very much like the bail on a hose bib. You remove the center screw and the handle can be lifted off the shaft. On my tractor, the decal covers the hole, but I can see the round impression where the screw is located. I hope your part is similar and this helps.
Thanks Jinman,
Yes, this is the same switch on all of the Boomers.
   / How do you remove turn signal switch on Boomers? #4
</font><font color="blue" class="small">( Thanks Jinman,
)</font>
/forums/images/graemlins/frown.gifNot all Boomers. Mine only has hazards, no turn signals.
   / How do you remove turn signal switch on Boomers? #5
my 33d doesn't have turn signals (2001). WHy on a tractor anyway??????????
   / How do you remove turn signal switch on Boomers? #6
</font><font color="blue" class="small">( my 33d doesn't have turn signals (2001). WHy on a tractor anyway?????????? )</font>
When your tractor has been around for 50 years and someone is rebuilding it as a antique, they can say, "Hey! Look at this switch. It's just like new; looks like it's never been used." /forums/images/graemlins/shocked.gif /forums/images/graemlins/laugh.gif /forums/images/graemlins/laugh.gif
   / How do you remove turn signal switch on Boomers? #7
because the laws in ohio and california require them. So it is easier to put them on all tractor instead of just tractors going to these states
   / How do you remove turn signal switch on Boomers? #8
</font><font color="blue" class="small">( </font><font color="blueclass=small">( my 33d doesn't have turn signals (2001). WHy on a tractor anyway?????????? )</font>
Ok, so where are these turn signals I've never seen?
)</font>
   / How do you remove turn signal switch on Boomers? #9
</font><font color="blue" class="small">( Ok, so where are these turn signals I've never seen? )</font>
Right there... in the attachment.
   / How do you remove turn signal switch on Boomers? #10
Thanks Jinman! (no I'm not SO stupid, my tractor is stored 5 miles away and I've had NO seat time this year due to the wet conditions. Mine is for my business use only. So I get no "play" or orientation time. And can't walk out to look. /forums/images/graemlins/smile.gif
2013 PETERBILT 367 DAYCAB (A58214)
2013 PETERBILT 367...
LOT: (5) Bolt Cutters (A59076)
LOT: (5) Bolt...
(INOPERABLE) GEHL 8K TELEHANDLER (A58214)
(INOPERABLE) GEHL...
PALLET TOTE OF MISC PARTS (A58374)
PALLET TOTE OF...
16001 (A55853)
16001 (A55853)
SCALES, PEA & BALANCE BEAM SCALES (A58374)
SCALES, PEA &...
