How do you reduce the PIA of greasing?
   / How do you reduce the PIA of greasing? #11
I have the lock n lube on my fixed tube gun and it works great most of the time, a few times the little release lever gets in the way. I have ordered the Univer-co for my flex tube gun to see if it will get in places the LnL will not. $30 free shipping (EBay $32 at Amazon), so same as Lock n Lube. Pricey to put on a $16 gun but I will see if it is worth it. I think Lock n Lube is worth the price, but then I am a guy who bought a pressure release gadget (releases pressure from hydraulic hoses- no cloth and hammer needed) from George Waite for $35 and I think that is worth it also.
   / How do you reduce the PIA of greasing? #12
For those of you doing lots of greasing and lots of money, try this one. Only $295 at Amazon and comes with a LocknLube coupler. It is a bulk grease dispenser (holds equivalent to 20 tubes of grease) with foot pump action.
Gurtech
   / How do you reduce the PIA of greasing? #13
Yep it is the LockNLube: http://www.tractorbynet.com/forums/oil-fuel-lubricants/304889-locknlube-cupler-grease-gun.html and: http://www.tractorbynet.com/forums/owning-operating/307933-review-locknlube-grease-gun-coupler.html
I put one on a hose, on the 10,000psi lever gun, normally you can't use a hose on a lever gun
You can put a hose on a leaver gun, I have been using lever guns with hoses for over 45 years and my dad did it before that. We never had a problem.
   / How do you reduce the PIA of greasing? #14
Two questions: How does it lock on and how much did it cost. I see it is made in Canada so not likely available in the states.
Pushes on like a spring loaded air or hyd QD as long as you hold from the back of it. To remove, grasp just in front of the larger ring and pull back. Easy 1 hand operation and only a mm or two larger than a conventional end.
Yup, made in Canada. No idea on US availability. I'd been looking for the LockNlube for a couple years and couldn't find it up here and finally came across this and am very happy with it.
X2 on the flex hose on a lever gun. I've been doing that for 30+ yrs and no idea how many yrs Dad was before that.
   / How do you reduce the PIA of greasing? #15
I would like to know how you hold the grease gun, operate the lever with one hand and hold the coupler at the end of the hose with the other hand.
   / How do you reduce the PIA of greasing? #16
Rest the barrel on the machine, crook of the elbow, on your bent leg close to the hip. Long hose is a big plus. Really isn't difficult, just not as handy as a pistol grip. The lever style usually delivers more pressure, and often more grease per stroke. A decent 4 jaw coupler will stay put most of the time if you don't put side pressure on it. If there were more decent quality gun couplers available, a high dollar lock'n lube wouldn't be so popular.
   / How do you reduce the PIA of greasing? #17
I have never had anything but a hose on any of my lever guns.
I generally use 2 hoses with a coupler for the extra length.
   / How do you reduce the PIA of greasing? #18
All you need is to have the coupler straight, you don't have to hold it, you don't have enough arm to hold it on anyway. That is why we use a coupler.
   / How do you reduce the PIA of greasing? #19
Exactly as RickB said. In fact, I'm not sure I've ever used a grease gun with a solid pipe.
   / How do you reduce the PIA of greasing? #20
Pig Statue (A55853)
Pig Statue (A55853)
2012 Ford E-250 Cargo Van (A55852)
2012 Ford E-250...
20 UTILITY TRAILER (A58214)
20 UTILITY TRAILER...
2018 Dodge Charger Sedan (A55853)
2018 Dodge Charger...
Informational Lot - Shipping (A55315)
Informational Lot...
2015 Ford F-450 Crew Cab Utility Flatbed Service Truck (A55852)
2015 Ford F-450...
