How do you fuel your tractor (logistics, not finding the cap to the tank)?
   / How do you fuel your tractor (logistics, not finding the cap to the tank)? #181
You can buy the "No Spill" spouts for $10-$12 on Amazon. Paying $32-$35 for complete can and spout makes no sense if you already have good cans.
Sent from my iPad using TractorByNet
Hmm. Have you actually been able to use the spouts on cans not made by "No Spill"? E.g., Blitz or Chilton. I just read the Amazon Q&A and the reviews, and they all seem to say they don't fit.
   / How do you fuel your tractor (logistics, not finding the cap to the tank)? #182
No, just started researching them. You are correct, they evidently only fit their cans. Please excuse my incorrect post.
My apologies.
   / How do you fuel your tractor (logistics, not finding the cap to the tank)? #183
True if the threads on the No Spill are the same as your existing jugs. I need to check my other jugs to see if the threads are compatible.
Before I found the No Spill, I bought a couple of the EZ Pour replacement spouts, and the threads were different than my jugs' threads. EZ Pour includes two different types of heads and neither one of them fit my jugs worth a darn, and both of them leaked.
   / How do you fuel your tractor (logistics, not finding the cap to the tank)? #184
55 gal drum and 12vdc pump. 8gal/min. So about 2 minuets to fill up. When drum is empty load on truck and go get it filled. Unload via FEL and done.
   / How do you fuel your tractor (logistics, not finding the cap to the tank)? #187
Seeing how my thread is still going 9 months later...
I've been using a transparentish 55 gallon plastic drum & manual pump. 1/2 or 1/4 gallon per stroke goes pretty fast, even with the water blocking filter on.
It sits on a pallet in the shop (no sun issues for the plastic). Just hit 100 hours on the tractor & am close to having to fill it up for the 3rd time. The local gas station has off road diesel & is only a little over a mile away. Pallet forks make loading/unloading easy.
Power Service white bottle has been keeping the fuel in good flowing shape.
I'm pretty happy with the setup after starting with a pair of 5 gallon cans, which were a pain.
This is EXACTLY what we do. Found the diaphragm pump on CL for 35 bucks, added the suction hose and a fuel/water filter...DONE! I can even pump with just one person if parked close enough to our tank.
   / How do you fuel your tractor (logistics, not finding the cap to the tank)? #188
This is what I am considering, as an upgrade to using four 5 gallon diesel cans. It wasn't that much of a problem filling the 1026R, but the 3720 has the fuel fill cap on top of the hood.
I'm aware that these fuel pumps can be DC or AC (or manual, of course). Ideally, I'd like to be able to fill by myself, which means having a nozzle with automatic shutoff, I think.
Anyone have any experience with auto-shutoff nozzles? Or opinions on AC vs. DC?
   / How do you fuel your tractor (logistics, not finding the cap to the tank)? #189
An auto-shutoff nozzle will work on a manual pump. I have one on my crank pump and it works well.
Aaron Z
   / How do you fuel your tractor (logistics, not finding the cap to the tank)? #190
Haven't read through the whole thread to see if this has been mentioned yet, but I use a 275 gallon heating oil tank with a Tuthill manual pump I scrounged somewhere.
I live in a fishing village and virtually all of the lobster boats are diesels, so off-road diesel delivery is readily available. I usually get 100 gallons at a time and treat it with a bit of algicide as 100 gallons will typically last me a year or more.
2014 International Maxxforce DT (A53317)
2014 International...
204158 (A57193)
204158 (A57193)
2018 Ford F-550 4x4 DurALift DTAXS39 39ft. Bucket Truck (A55973)
2018 Ford F-550...
2014 Ford Transit Connect Cargo Van (A54814)
2014 Ford Transit...
2014 DITCH WITCH RT45 (INOPERABLE) (A58214)
2014 DITCH WITCH...
Auger Drill Bit (A56857)
Auger Drill Bit...
