How do I get this boulder out of this hole?
   / How do I get this boulder out of this hole? #21
Years ago I had to remove a big rock from my new garden. All I had was my 1945 Gibson tractor. Look up Gibson tractors to see what I had. Anyway, a 7 hp Wisconsin engine was all the power I had. I dug a ramp down to the rock. Then I wrapped a chain basket made from tire chains around the rock. At least a 400 pound rock. I jerked and jerked until the rock started to move up the ramp. Once I got it moving I didn't stop until I had the rock where I wanted it. So a ramp is a good idea I think. Drag the rock onto some sort of sled, maybe a piece of 3/4 plywood or an old car hood. Water the ground heavily along the path you want to drag the rock so it is extra slick. Drag to desired location. Or, as someone else suggested, hire a big wrecker to pick and place it.
Eric
   / How do I get this boulder out of this hole? #22
   / How do I get this boulder out of this hole? #23
Your in New England right?
Try digging down like FatJay wrote, water the ramp so it freezes over, put in posts at top of the ramp to attach cable/heavy rope, winch rope and rock up ramp if you don't have something to tow it with.
   / How do I get this boulder out of this hole? #25
Assuming 7' by 5 or 6' that boulder probably weighs in excess of 20,000lbs. Big tow wrecker with crane and sling.
Yep. I would just back my (underrated) 10-ton crane up to it, position two slings, and lift it out.
Is there something I'm missing about this simple task?
   / How do I get this boulder out of this hole? #26
I know the op doesn't have a crane but paying wrecker is how I would do it. I think a lot of comments are greatly underestimating the weight. It is probably in the 24k to 26k range.
   / How do I get this boulder out of this hole? #27
This is the typical New England boulder and Cat 315 2x the size of the OP machine but was a struggle.
5'H x 6'Wx 10' L a bigin..
   / How do I get this boulder out of this hole? #28
Wish I had pics of some of the boulders I moved with my old steel track.over tires JD 326 ss , and a heavier duty stump bucket with grapple. As long as I could get the boulder to move by digging down around it in a hole with stump bucket I could use the bucket like a pry bar to pop it out of hole to more level ground.and push it down an embankment, off a logging two track I was helping make more useable for vehicles to access a camp. Dangerous, problaby, but it worked without any noticeable damage to 326 or injuries. . you will problaby. Have to push a rock that size if you manage to get it out of the hole. Me anyway I'd never try pushing something that big up an incline. Good luck.
   / How do I get this boulder out of this hole? #29
If you can’t budge it even a little, like you said, meaning not the slightest movement in any direction with your mini excavator, that would lead me to believe it’s attached to a larger rock formation underneath. You should probably look into how large the attached area is, before you move forward with trying to lift it out. You might have to break it up, or at least break the attachment area first
   / How do I get this boulder out of this hole? #30
One method Ive used in similar situations, is to lift up high, another large boulder with your excavator and drop it on that one. Don’t get the machine too close… eye protection required..
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
1302 (A58374)
1302 (A58374)
2015 Jeep Compass SUV (A56859)
2015 Jeep Compass...
2014 FREIGHTLINER  CASCADIA (INOPERABLE) (A58214)
2014 FREIGHTLINER...
2019 CATERPILLAR 326FL EXCAVATOR (A52709)
2019 CATERPILLAR...
2012 INTERNATIONAL PROSTAR+ (A58214)
2012 INTERNATIONAL...
