How did this Tractor Flip?
   / How did this Tractor Flip? #21
Since we're all guessing...
IF the trailer hitch was on the draw bar and IF the hitch was a standard ball and IF the rear tires did not break traction, it's possible the trailer's tongue weight in conjunction with the slope stopped forward movement. The rear tires had enough traction to rotate the tractor around it's rear axle...during the rotation, the hitch ball disconnected from the trailer's hitch receptacle.
All speculation, of course...but that's my guess.
   / How did this Tractor Flip? #22
My two cents: no draw bar and pulling from the 3ph, which floats up as the tractor does its "wheelie" ...a stout, fixed drawbar would have acted a little like a wheelie-bar
   / How did this Tractor Flip? #23
Ford N series widow maker. Owner/operator could not find the bucks for a real drawbar. So they used the three point hitch. Small tractor with too much load on too much hill began to spin. Operator jerked the three point hitch up for traction. Up and over she went.
   / How did this Tractor Flip? #24
My WAG :3ph too high and when he came to that grade with way too much load on behind he ran out of power and lugged down. He stopped and shifted gears, perhaps down two instead of one then popped the clutch!!
   / How did this Tractor Flip? #25
I agree: no drawbar, 3 pt hitch too high, no rops.
The first two things caused the tip over, the last exacerbated the injuries to the operator.
One thing that absolutely did not happen is that the tractor rotated about the rear axle. If you watch video of this kind of turnover it looks like this happens, but only because this is what you eyes and brain expect to happen. I have watched many videos of this type of turnover. If you slow them down enough and really pay attention, the the pivot point is the place where the rear wheels contact the ground.
   / How did this Tractor Flip? #26
I agree 3 pt hitch too high and above center. Recipe for death. I am glad the guy was only injured. Lesson: USE A FRAME MOUNT DRAWBAR, NOT 3 PT DRAWBAR
   / How did this Tractor Flip? #27
Probably didn't have stay bars on the 3 point to keep it below axle level. A 3pt floats so you wouldn't have to lift on it
"the pivot point is the place where the rear wheels contact the ground." The rear wheels can't move so they stay put and the tractor rotates on the axle the wheels are attached to. It's less force to flip the tractor than to pull the wagon. It does happen very fast.
   / How did this Tractor Flip? #29
The load on the trailer is Kiwifruit and he was taking the bins from the pickers, to the loading point. The drivers are usually youngish (although this guy was 61) and going like.....(rather quickly). There is no ROPs as the tractors have to fit under the vine overhead. He had just come to the end of the row and was about to turn. Turning at the end of the row is usually yank the wheel over and stab the brake on the inside wheel. The gang is paid by the bin and there is a lot of pressure to finish and move on to the next orchard.
I am surrounded by Kiwifruit orchards.
   / How did this Tractor Flip? #30
That contradicts my post...and I kind of agree with you. Now, I've never watched slow motion videos of a tractor doing a back-flip...well, apparently not as close as you have. But, if the tractor's rear tires don't rotate and the mass of the tractor does have to rotate...I cannot see anyway it could not rotate about the rear axle.
As an example from many years back...there was a farmer (in Nevada, IIRC) who had left his tractor on his field one day. The next day he started his tractor, engaged a forward gear and the tractor rotated about the axle as the rear tires were frozen to the ground.
Granted...the contact point of the tires to the ground was the cause, but it seems the axle would still have to be the rotational axis...not the tires' patch
Does that make sense?
Kubota RTV X900 (A53317)
Kubota RTV X900...
flooring (A55758)
flooring (A55758)
2013 Chevrolet Caprice Sedan (A56859)
2013 Chevrolet...
2015 International Durastar 4300 SBA 4 x 2 Water Truck, VIN: 3HAMMMMN4FL510006, Cummins Turbo Die... (A59076)
2015 International...
2008 Caterpillar G23G Scraper, S/N CAT0634GADBY00493, Cat Turbo Diesel, 12,763 Hours Indicated, (A59076)
2008 Caterpillar...
2005 EZ-GO Utility Cart (A55851)
2005 EZ-GO Utility...
