Soundguy
Old Timer
- Joined
- Mar 11, 2002
- Messages
- 52,424
- Location
- Central florida
- Tractor
- RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
got a huskee lt3800 with a 12.5 brigs in it ( good mower by the way! )
wet to do an oil change on it today.. notied that if you go by the brigs engine specs.. it takes a filtr that is 200ml larger in capacity than if you use the mtd spec oil filter. IE.. when you buy the machine.. you get an mtd mower owner manual, and a brigs engine manual.. under the hood there is an mtd oil filter #, in the brigs manual is a brigs #.
both filters fit obviously.. however the mtd filter is about 1/2" shorter and maybee 1/4" narrower. brigs filter actually is larger diameter than the oring seal area where mtd filter diameter is same as oring diameter.
I opted for the brigs filter... more oil capicity can't be worse....
any ideas why?
any ideas why?
