Comparison Home Stand By Generators
   / Home Stand By Generators #301
Not sure if the installer should be the one to adjust your valves but I am sure some are very mechanically inclined to do so. I know my installer will come and do the maintenance when required but no need as I am capable of servicing my own. I have been doing my own small engine repairs for years and these generator engines are just that.
Valve adjustments are relatively easy to do especially on engine where the head valves are positioned at the front of the engine and at easy access. All you need is a wrench, valve gauge and the owners manual or go online and see a video on how to do it.
As for the distance of any objects or vegetation should me 10' or more away from the exhaust.
What's a "valve gauge"? never heard of it.
I bet you are talking about is what are known to mechanics, as feeler gauges.
   / Home Stand By Generators #302
You knew what I was talking about. Thank you so much for correcting me. Gauge sounds better that feeler no matter what it does the same job.
   / Home Stand By Generators #303
No need to be snippy like that when someone is trying to talk to you. I said I think I know the tool you were referring to.
I'll try to ignore your posts in the future.
   / Home Stand By Generators #304
Good ignore my posts I don't care.
   / Home Stand By Generators #305
I have a question about adjusting the valve lash on a Generac/Vanguard engine.
Does the Generac approved installer actually know how to do that or is he "just an electrician"?
Since when did electricians adjust valves? So then, who to get that will do it competently and actually come out to your home? I'd be worried about someone leaving it worse than he found it if he has little experience doing this.
The electrician who did my install is a certified Generac guy who can work on the mechanical side as well. I asked him about the suggested valve adjustment intervals and he swears that very few ever need it. I don't recall his exact words, but he said if they need the valves adjusted you'll know it because they don't start easily. I'll probably do it anyway (I can handle that one), at least once to verify, but he's been installing them for many years, so I can't imagine he's making it up, and after watching him work, he's kind of a perfectionist.
   / Home Stand By Generators #306
We are mixing 2 trades here. Electrician and mechanic. Rarely is a person both and in today's world to be certified in both is virtually impossible.
Long live the good old handyman!
However that being said valve lash is very easy to adjust, A handful of tools and feeler gauges is all it takes. Naturally new gaskets will be required.
Problem is that the engine specs are rarely included in the owner's manuals so you typically need to guess the proper lash. Also where to obtain the gaskets and I'll bet the generator supplier has none in stock.
The same conflict exists with water pumps as a plumber installs but an electrician is supposed to do the hook up.
The generator man can not repair the engine portion and the engine shop can not repair the electrical portion. Fun eh!
Add to that that virtually all the engines used are ChiCom and to the best of my knowledge generally not supported as are Briggs, Wisconsin etc.
   / Home Stand By Generators #307
So... To get back to the original question.... Which are the best Standly generators?
So far, we have My earlier comment that the dealers felt that Generac generators were not good ones when I was purchasing mine 5 years ago, and one other poster who said that his neighbors have had problems with Generac.
I myself have a Kohler RES17 (17 kw), and I have had a couple problems with it.
Anyone else want to chime in?
   / Home Stand By Generators #308
My Generac 11 kw Guardian has not given any problems yet so to me they are the best. Now if I did have problems then that would be another story. IMO Generac generators are well recognized as a durable, efficient running generators. What else can I say some are good and some are bad until you hit a bad one you don't know.
   / Home Stand By Generators #309
The consensus from the dealers that I have spoken to seems to be that Cummins makes the best ones.
That's what a friend of mine bought, and he is an electrical engineer who uses generators all the time.
   / Home Stand By Generators #310
Cummings now you are talking diesel. Yes they are the best of course. I was talking about average home propane generator. Generac standby genrerator are only in NG or LP sorry for not mentioning that. Generac propane generators are the best to me lol
2018 Ram 5500 Chassis IMT 2820 5,000LB 2.5 Ton Crane Service Truck (A55852)
2018 Ram 5500...
2020 JOHN DEERE 333G SKID STEER (A52707)
2020 JOHN DEERE...
(APPROX.48) UNUSED 2X4X10 PREMIUM GRADE LUMBER (A57192)
(APPROX.48) UNUSED...
UNUSED FUTURE P45 56" HYD BREAKER HAMMER (A57193)
UNUSED FUTURE P45...
2020 CATERPILLAR 259D3 SKID STEER (A52707)
2020 CATERPILLAR...
UNUSED RAYTREE RMBD72-72" HYD DRUM MULCHER (A57193)
UNUSED RAYTREE...
