Home made tractor cab
   / Home made tractor cab #4
Looks like it will be nice and cozy!!
Got to spend 3 years at KI Sawyer (never made it up to your neck of the woods).
Arrived there on a Friday in mid-December and there was still green grass, thought the "snow" stories must have been someones imagination.
It started snowing Saturday and by Monday morning there was 32" on the ground, as I recall the average was 120" or so.
Can only imagine the amount of snow you get... 150+ inches?
We get anywhere from 180 in. To 400 in of snow per year with about an average around 250 to 300
So that will give the little kubota a workout ��
   / Home made tractor cab #7
Nice job on the cab and the accessories. Were did you get the wiper motor and wiper arm? I would like to install one on my skid steer. I found motors at surplus center, but they do not list a wiper arm to fit.
Dave
   / Home made tractor cab #8
I really like that whole setup! Snow removal isn't usually pleasurable but that cab with a heater and a wiper should make it a whole lot closer to being! I have the same question... Where did you find the wiper set up as well as the heater core? Does the heater core have a fan behind it? One last question I see how you're getting the coolant to the core but how do you return it?
Hi Jason
I purchased the wiper motor at Surplus Center and bought the wiper arm from my local auto parts store . The wiper arm is a universal with adjustable length, the shaft on the motor is a common size.
The heater was purchased at https://www.tractorpartsasap.com/Auxiliary_Heater_p/111417.htm yes it has a 2 speed fan. I tapped into the thermostat housing for the supply to the core it is British pipe thread but standard pipe is close in size and works just fine. As for the return to the engine I cut the lower rad hose and made a tee to install in it. Heater works great only takes 5 min to get heat when cold. Hope that helps.
   / Home made tractor cab #10
Thanks I understand now..:cool:
2020 INTERNATIONAL LT625 TANDEM AXLE SLEEPER TRUCK (A51222)
2020 INTERNATIONAL...
Hyster H155XL Forklift (A48837)
Hyster H155XL...
2023 John Deere 8R410 MFWD Tractor (A51039)
2023 John Deere...
2016 Ford F450 (A49461)
2016 Ford F450...
Lot of 2 2017 Stihl TS800-16 Concrete Saws (A48083)
Lot of 2 2017...
2018 Dodge Ram 5500 Bucket Truck - 4x4, Versalift VST40, 45FT Reach, Dakota Line Body (A51039)
2018 Dodge Ram...
