home made disc
   / home made disc #11
Spray some graphite or similar lube on your tube or it wont take long for it to rust together.
   / home made disc
what tube? i put zerks on the adjuster nut and slide tube thing if that is what you are talking about. it might work well until i drop something on the threads
   / home made disc #13
Your design looks to mimic a disc I once saw but I believe that it still used pins through the frame to hold the front and rear gangs in place. The screws were just there to move the gangs. I think I would look at putting pins in the holes that should be in the frame so the set can be matched front to rear. I think the holes lined up so there was a pin in front and one in back of the slide plates holding the gangs together.
   / home made disc #14
I think maybe the poster was referring to the top and bottom of the center tube, where the gangs actually move fore and aft to adjust the gang angles. Adding grease to the threaded adjustment shaft and the grease fitting goes without saying.
   / home made disc
thanks spo307. i put the holes in the center tube but they are now covered by the screw. i might drill or add in front of the slider to hold it in place. next step is to finish the three point brace. i am amazed the 2 pieces of 3/4x 1/4 flat bar with crappy quick tack welds has held so far
   / home made disc #17
I like your work, but I think you are going to mess up the threads on your adjusting rod even if it holds up.
   / home made disc
yah! that is a big concern for me. i think i'm gonna build a cover for it. box it in somehow. iv'e only disced the arena so, its already pretty soft so no real test there. haven't had any rain since i think march, so if we get rain in October ill be able to test it for real without all the dust.
EquipmentDealz (Shipping Terms and Instructions) (A59213)
EquipmentDealz...
2006 Toyota Prius (A56859)
2006 Toyota Prius...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55853)
2006 iDrive...
2017 Gravely Pro-Turn 460 60in Zero Turn Commercial Mower (A55973)
2017 Gravely...
2012 John Deere 624K (A55272)
2012 John Deere...
SEMI AUTOMATIC QUICK-CHANGER FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
