High Pressure Leak Horror Story
   / High Pressure Leak Horror Story #1
x703jko
Maryland
Kubota BX24TLB
When the tech from Finch Services was at my place on Monday to look at my BX24, I asked him about the warnings regarding high pressure leaks from a pinhole in a line.
He says that he knew a guy who apprenticed at another shop. One day he and the senior tech he was apprenticing with were trying to track down a leak in a 10,000 psi ag tractor. As the guy put it, the senior tech glanced away for a second as the apprenticed saw a puff of mist, which he then ran his hand across just as the senior tech turned to look back...the senior tech clearly saw a puff of "red" from the top of the apprentice's hand...the apprenticed noticed nothing...felt nothing.
The high pressure stream pierced the apprentices hand completely through...
The senior tech then shut the tractor down and immediately applied a tourniquet to the apprentices arm and the rushed him to the hospital....by the time they got there...the apprentice was unconcious, barely breathing, and his arm was swollen twice it's normal size.
They managed to revive him (he was actually poisoned by the SUDT), but they had to amputate his arm above the elbow.
Scary... :eek: :eek: :eek:
   / High Pressure Leak Horror Story #2
That is a scary story:eek:
You should have put it in the safety forum!
   / High Pressure Leak Horror Story #3
10,000 psi.......yikes! Must be some type of prototype.
   / High Pressure Leak Horror Story #4
I wondered about that and tried to find 10 kiloPSI hydraulic hose, and it exists. The manufacturer termed it extremely high pressure hydraulics.
   / High Pressure Leak Horror Story #5
A good example of a 10.000 psi hose is the port-a-power hose. Mine is. A lot of the 1/4 hose is rated to 10,000 psi. It seems like the larger you go in hose sizes, the psi decreases, probably because of the surface area.
2014 DITCH WITCH RT45 (INOPERABLE) (A58214)
2014 DITCH WITCH...
UNUSED 2026 INDUSTRIAS AMERICA 7014R DUMP TRAILER (A57192)
UNUSED 2026...
UNUSED FUTURE 12" HYD MINI AUGER (A57193)
UNUSED FUTURE 12"...
2005 Interstate 7x14 Trailer (A55973)
2005 Interstate...
2023 John Deere XUV 825M S4 (A56469)
2023 John Deere...
2013 Ford Taurus (A56859)
2013 Ford Taurus...
