Jerry/MT
Elite Member
- Joined
- Feb 2, 2008
- Messages
- 3,135
- Location
- North Idaho-The Palouse
- Tractor
- New Holland TD95D, Ford 4610 & Kubota M4500
Our TD95D require replacement of the cab heating hoses. This requires removing the cab roof to gain access to the hoses that supply the heater heat exchanger. These pass through the A pillar from the roof and then to the engine connections.
I have the NH CD service manual for this tractor and I have attempted to follow their poorly written instructions and the roof will not budge. It says there are four bolts but all I have found is two bolts and 2 nuts with accompanying studs. I thought maybe the light bar bolts were also holding it down so I loosened them but its till will not budge.
Has anybody out there removed a NH TD95D cab roof and if you have how did you do it?
