Help on a B6100 4WD
   / Help on a B6100 4WD #1
farmall49
Looking at a '79 B6100 with 4WD. Need to know the specs. on it. (ie: 3-pt capacity, loader capacity, weight...) Please let me know if their is a site with the info. on these older model tractors.
Thanks in advance.
-Eric
   / Help on a B6100 4WD #2
Try a search on the kubota Site .
That link will give you some of the information you seek.
   / Help on a B6100 4WD #3
I can't answer all your questions, but I do know the B6100 is 14HP. I had one for a long time. They are very strong little tractors.
   / Help on a B6100 4WD #4
A couple of the earliest US Kubotas had reverse-rotation PTO's.
You might want to see if this was one of them, if you need the PTO.
   / Help on a B6100 4WD #5
I have a b6100E which is 2wd....does this one have a HST trans...i'm assuming its gear since its a 79. The lift capacity on the 3 point is only 300 pounds according to my manual, it has 14 hp. I dont believe it has reverse PTO well mine doesn't. If u need more help just post again
   / Help on a B6100 4WD #7
B6100 PTO spins the correct direction, it was the older B6000 that ran backwards.
   / Help on a B6100 4WD #8
I have a '78 B6100DT (4wd, gear tranny). I'll look up the specs in my owner's manual when I get home tonight and post them.
Bill
2014 VOLVO VN SERIES DAY CAB (A50854)
2014 VOLVO VN...
Power Equipment Log splitter (A50860)
Power Equipment...
TRAIL MASTER  DETROIT-TRIPLEX PUMP TRAILER (A50854)
TRAIL MASTER...
2007 MACK GRANITE ROLL OFF TRUCK (A51222)
2007 MACK GRANITE...
2021 Cat D5 LGP Dozer (RIDE AND DRIVE) (A50774)
2021 Cat D5 LGP...
Gravelly Pro-Turn 148 48in Zero Turn Mower (A48082)
Gravelly Pro-Turn...
